Sears Yellow Jack - letting it down slowly?
Old Mar 10, 2010 | 11:19 AM
Keithhu's Avatar
Keithhu
Default Sears Yellow Jack - letting it down slowly?
Yes, I know, another SYJ thread, sorry. (BTW bike seems pretty stable when its up, so I dont see the problems others have had)
When I let the bike down, I tried very hard to twist the handle just a tiny bit so it would go down slowly.
Not successful. SHUNK! WOBBLE. Holy crap.
Bike was fine, but is this just something I have to get used to?
Old Mar 10, 2010 | 11:36 AM
BigCedar's Avatar
BigCedar
I purchased a Cummins jack from a friend and it lets me ease it down. I still get nervous when the bike sets down on the stand.
Old Mar 10, 2010 | 11:47 AM
cromagnon's Avatar
cromagnon
I have a sears yellow jack.
Letting it down slow is impossible .....
Sorry friend
Old Mar 10, 2010 | 11:53 AM
cadman311's Avatar
cadman311
Sorry but sears yellow jack work well it the operator.
Old Mar 10, 2010 | 11:55 AM
DuraGlide's Avatar
DuraGlide
I have the SYJ and it will let down slowly. Just takes practice Using the minimum amount of torque to close the valve helps. On a side note I found most of the button head bolts that hold the rear wheel brackets on were loose the other day. I've had mine about 3 years.
hdstreetglide08's Avatar
hdstreetglide08
I don't have a problem with mine going down slowly
Old Mar 10, 2010 | 11:59 AM
cadman311's Avatar
cadman311
I have car jack Pep boys it has a problem with it. I drilled a hole in the handle for a long bolt makes it easyer to turn with control.
Old Mar 10, 2010 | 12:09 PM
Keithhu's Avatar
Keithhu
OK, thanks guys - I guess practice, and I might try putting a rod in the handle to make it easier to open slowly....
Old Mar 10, 2010 | 01:17 PM
SalsaNChips's Avatar
SalsaNChips
I have a Harbor Frieght jack that does the same thing -- nearly impossible to let it down slow. You'r supposed to fully depress the floor pedal on the jack for slow lowering (which is NOT intuitive). First time I tried it I my FXST hit the floor so suddenly I lost it and it fell against my '98 Mustang GT, the handlebars putting a sizable dent in the passengers side door. Oh well, lesson learned.
Old Mar 10, 2010 | 01:23 PM
snakeinthegrass's Avatar
snakeinthegrass
I learned real quick to twist the handle ever so slightly to lower the bike down sloooow on my SYJ. One thing that might help if it is a new SYJ is to have someone stand on the lift while you run the jack up and down a few times to pump up the fluid. Back in my mechanic days we always pre primed the shocks before installation. Prevented dead air zones.
