Easy Brackets
Old Mar 29, 2010 | 03:30 PM
Slopneck's Avatar
Slopneck
Default Easy Brackets
Yo! I searched around but didn't find an answer to my question so here goes. I'm thinking about picking up a set of Easy Brackets to use with some bags. I already have the HD Docking Hardware installed for a quick release sissy bar. Has anyone tried using the Easy Brackets with the HD Docking Hardware? Does it work? If not, could it be mod'd to work? The EB hardware looks similar but I can't be sure.
Thx.
Old Mar 29, 2010 | 03:45 PM
MISFIT456's Avatar
MISFIT456
I used easy brackets on my 07 Fatboy with the Harley quick detach sissy bar, just drilled through side plates and used the hardware from Easy Brackets.
Old Mar 29, 2010 | 05:23 PM
71FLH's Avatar
71FLH
Easy Brackets can be ordered for quick release or solid mount. Their website breaks it all down. Hope this Helps.
http://www.easybrackets.com/
Old Mar 30, 2010 | 07:58 AM
TequilaJohn's Avatar
TequilaJohn
Yep, I ordered a set to work with the quick release sissy bar on my Deluxe...works great. A little tip for laying them out on your saddlebags. Get one bag laid out like you want, drill the holes to mount the easy brackets, and then mount everything up on that side to make sure it's how ya want it. Then remove the easy bracket from that bag, lay the bags back to back, and mark the holes on the other bag thru the holes on the one ya just fitted...perfect alignment of your bags on the bike.
Mx Convert
May 21, 2010 10:30 PM
don03
May 15, 2009 08:49 AM
JRK5892
Apr 24, 2009 12:37 AM
Frankster69
Sep 3, 2008 11:38 AM
bobros
Aug 10, 2006 11:25 PM
