Dead engine after 50K miles
Old Apr 2, 2010 | 07:40 PM
mp's Avatar
mp
With the horribly inadequate main crank bearing and the bits of tensioner continually being circulated in the oil throughout the engine, not to mention the overheating problems, I'm surprised it doesn't happen to a lot more Twin Cam engines.
Old Apr 2, 2010 | 07:42 PM
cdale976's Avatar
cdale976
let me guess the casing started leaking on the bottom end on the bottom of the engine.....
either way I'd see the engine come apart and have the paperwork on service handy. Gotta be worth some change
Old Apr 2, 2010 | 07:45 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Call your insurance agent and find out who handles their salvaged motorcycles and see if you can find a 2006 B motor off a wrecked bike.
Old Apr 2, 2010 | 07:48 PM
Faast Ed's Avatar
Faast Ed
These tensioners had less than 30 k miles on them.
I'd be curious as to what yours looked like in the failed motor.
Old Apr 2, 2010 | 07:54 PM
BLKBAGGER's Avatar
BLKBAGGER
Originally Posted by Faast Ed
Tensioner failure? Clogged the oil lines?
Definately enough miles for that.
That was my first thought too. When the tensioners wear out they can take out the motor real easy. I check mine every 20,000 miles and replace them if they are showing wear. Still just a guess though. It could be the crank or oil pump failed too.
Old Apr 2, 2010 | 07:56 PM
leeinmemphis's Avatar
leeinmemphis
for $4k you can build one heck of a nice aftermarket motor. That would be my choice.
Old Apr 2, 2010 | 08:48 PM
babalu's Avatar
babalu
i doubt the dealer is trying to sell you on an engien if it didn't need it, a top end rebuild is a big money maker for them. if the bottom end of the engine was good to go they would just sell you the farm in cylinders, heads etc... and make a nice labor charge.
Old Apr 2, 2010 | 08:49 PM
KBFXDLI's Avatar
KBFXDLI
What was the engine doing to cause you to take it in and for them to disassemble it? I am just curious about a few things:
1. What service did you have done at what intervals?
2. What oil/filter did you use? Who changed the oil?
3. Did you ever inspect and or change the cam tensioner shoes?
4. If they did change the tensioner shoes was the crank runout checked?
5. What internal parts failed?
6. Was it lubrication failure?
7.Was the bike modified from stock?
8. if so, what mods and by who?
9. Did the engine ever consume oil? How much at what mileage?
Old Apr 2, 2010 | 09:51 PM
wescoot2's Avatar
wescoot2
Multiple internal problems.........I wonder how they came to that conclusion before ripping it down.
Old Apr 2, 2010 | 10:16 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
you used Syn3 didn't you.
