I installed a Hypertech mod in my '94 Corvette a while back and pulled a dynoed 15 extra horse power and 25 lb/ft of torque in my otherwise bone stock car.
So I'm wondering...
I'm planning on a K&N filter and the V&H Big Radius 2-into-2 pipes for my '07 Dyna. I know the retro PC-V will benifit me after the mods, but I'm wondering about installing it before the mods. Would I see any gain there as I did on my Corvette? I know they're two different animals, but I still think it's a valid question and to some limited extent a fair compairson, and since Fuelmoto will make adjustmens to the module to accomodate future mods, that opens up my options.
Or should I do the mods first, and then the PC-V? I don't have the bucks to do it all at once, so I'm havin' to take it a step at a time and I'm not sure what order to do these things in.
If can't do them but one at a time .. Would go PC V, High Flow Intake , then Exhaust in that order .. Although is nice to do them all at once and do the final tune and be done ..
here's my .02, brought to you free of charge and worth every penny it cost you...lol
because of EPA restrictions and the overly lean condition of stock bikes, there's probably a miniscule amt of benefit to be had by installing a pc by itself. but we're talking so much lower potential from the v twin engine vs the vette engine that any small percentage points of gain would be nearly impossible to measure and definately not worth the investment.
your engine is an air pump. opening either end by installing new a/c OR a new exhaust will not yield any results, because the restriction still exists either in the intake or the exhaust which will restrict the pump from increasing output. only by installing the a/c in conjunction with a free flowing exhaust will you see an increase in the air pump's (the engine's) output. this is when the PC comes into play to correct the air/fuel ratio to compensate for the leaner mixture which is the result of more air in the system.
As a result, I would add a nice exhaust first, to get the sound (but no hp gains), then save my $ and do the a/c and the pc at the same time to get the benefits from the entire stage 1.
I'm a complete novice but this makes complete sense to me. I have all 3 but if I were only able to do 1 at a time it would definitely be the pipes first, then the PC-V and then the A/C. Now the only reason I was able to do all 3 at the same time is because I got my V&H slip ons and the AN Big Sucker used, otherwise it would have been OAAT for me too.
I would do the PC first. These bikes run lean do to EPA regs. With the bike in stock trim (intake/exhaust) you are going to benefit in richening up the A/F ratio. The bike will run cooler and better. A canned mapped from Fuel Moto should do fine. Down the road when you can do the intake and exhaust, you should also save your pennies for a custom map if you want your bike running in top form.
A quick question about the PC-V, I undersatand the tuneing of the A/F ratio and making the bike run better especially with a stage 1 done but, I was wondering if this will also improve fuel milage? Thanks, and I don't mean to hijack this thread.--Troy
Ho'd on, ho'd on! You mean just having slip on's is considered "opening up" the exhaust? I didn't realize that. I have V&H slip ons and the previous owner took the baffles out. I don't have anything at all in them. Am I reading that right?
