Xieds????? Need Help!
Old Apr 23, 2010 | 05:40 PM
BLK08ROCKERC's Avatar
BLK08ROCKERC
Default Xieds????? Need Help!
Ok guys I bought a set of Xeids from another forum member here awhile back for my father. Well he has finally changed his exhaust and we are going to be installing them tommorrow.
My question is where so the go? I did not get any instructions so I am lost. They will be going on a 07 Heritage. Any help will be greatly appreciated!
Old Apr 23, 2010 | 05:55 PM
Saxon's Avatar
Saxon
www.nightrider.com
Check out their website - there are instructions there. Really a very simple install, should take 5-10 minutes
Old Apr 23, 2010 | 06:03 PM
krusty1's Avatar
krusty1
They go between the end of the lead from the O2 sensor, and the cable from which you unplug the sensor lead. Just follow out the wire from the O2 sensor, unhook the first coupling you come to (it snaps together/apart, and has some integral water-resistant seals) and put the XIED between the two. The front 02 sensor (on the front exhaust header) lead goes down to the voltage rectifier regulator area, and the back 02 sensor (rear exahust header) goes up under the seat. (At least that's where they went on my 2010 FXD). If you wiggle the 02 lead around you'll be able to easily identify the correct cable under the seat.
Make certain if you end up with a lot of extra wire tie the bundle off with a wire tie (you obviously don't want them contacting the hot exhaust system or engine), and make sure that when you plug the XIED into the circuit it snaps into place (they can be a little tough to push all the way in....you should hear a click). It's no more difficult than 'daisy chaining' a new piece of cable between the ends that were once connected. One end of the XIED cable is male, and the other female....you can't go wrong. It's about as complicated as hooking extension cords in series.
Old Apr 23, 2010 | 06:06 PM
dbinbc's Avatar
dbinbc
Yes, the Nightrider site has instructions. They install in just minutes. Unplug the plug that is about 6 or 8 inches back from the 02 sensor in the header pipe and connect the Xied to the ends of the wires you unplugged. The plugs only go one way so you can't do it wrong. Do the same with the other pipe. You may want to zip tie the wires to secure them at the front. Its that easy and they work great. Bike will run smoother and sound a bit deeper.
IndyClassic's Avatar
IndyClassic
Originally Posted by Saxon
www.nightrider.com
agreed.......If I remember correctly follow the lead off each exhaust sensor back to the first connector, unplug and then plug the Xied to make the circuit complete again.
Hopefully nightrider will have nice pictures for you.
Old Apr 23, 2010 | 06:28 PM
BLK08ROCKERC
Cool!!!!!!!!! Thanks for the help guys!!!!!!! That sounds pretty easy!!!!!!
Old Apr 23, 2010 | 07:44 PM
Lost1's Avatar
Lost1
And they actually work as advertised. Best thing I ever did to my bike.
UltraDune
Sep 10, 2011 05:45 PM
rebel66
Jul 18, 2010 09:34 PM
ScReaMnEagLE22
Exhaust System Topics
Jul 8, 2009 07:48 PM
Wrongturn
Mar 13, 2009 09:06 AM
intempestivus
May 20, 2007 12:15 AM
