I am using this setup, a Garmin etrex Vista HCx with a Ram-mount on the handlebar. The etrex has a micro sd card which I have all of Canada and the USA maps on. It supports turn-by-turn routing.
The etrex is waterproof and runs on AA batteries. I carry some extra Ni-MH batteries and swap out as needed. I get several hours on a freshly charged set with the backlight set on a lower power setting. If travelling, I can get AA batteries cheap at the local Walmart if needed.
Works well for me and didn't have to run extra power cords/wires.
I use my Nuvi 255 on the bike occasionally, to date I just mount it with the suction cup to the windshield. However, I would like to find an easy on-off mount and have looked at those on Amazon. My main concern is really how strong is the mounting? If it's made for a bicycle, would it hold up to the vibrations of road speeds?
Does this work well for road travel? I thought they were more cross country type thing...does it have all the road maps and tell you which road you're on, when to turn off etc?
I liked the larger screen for using w/ gloves. This one requires 12-volt power from the bike. Anyone have any suggestions for connecting on my Custom? Perhaps that should be asked in do-it-yourself.
Thanks for all the inputs.
Battery tendar pigtail off of bike battery .. $5 adaptor for 12 V. That is my set up for all things that use a 12 v. That way you can use a battery tender in winter.
