affordable GPS
Old May 18, 2010 | 03:11 PM
  #41
lo-rider's Avatar
lo-rider
Default installed
Originally Posted by lizdc
Battery tendar pigtail off of bike battery .. $5 adaptor for 12 V. That is my set up for all things that use a 12 v. That way you can use a battery tender in winter.
Thanks Liz,
that's basically what I did--bought the battery tender and installed the pigtail that comes with it; bought a cell-phone adapter and just plugged them all together. By splicing some wires I was able to run the GPS cable inside the existing conduit under the tank. Fuse is accessible behind the battery cover.
When I return from another road trip I'm just about to leave on I'll post some photos--probably as a new thread?
Old May 18, 2010 | 03:59 PM
  #42
bhunter00's Avatar
bhunter00
I have garmin nuvi 500 it is water proof and not as costly as the one they sell for motorcycles
Old May 18, 2010 | 04:17 PM
  #43
OsoFat's Avatar
OsoFat
Tom Tom One 130 and a Ram mount. It's not water proof, but fits in a zip loc baggie. You can find the GPS on ebay, new for about $75 and the mount runs about $30. Like other posters have said, you can power it off your battery tender or it'll hold a charge for about 3 hours.
Old May 18, 2010 | 04:30 PM
  #44
fireman-jim's Avatar
fireman-jim
3rd Gear
Here's a good website for many different mounts. Enjoy!
http://www.mountguys.com/
Old May 18, 2010 | 04:33 PM
  #45
fireman-jim
3rd Gear
Wink GPS / Phone mounts
I am worride about having my iphone on my bike. 1 I will break it. 2 I get calls texts ect they will pop up and I will get distracted.
What map program do you use? I mainly use my phone but have in my pocket.
Also can you send me the link to the bike mount?
Heres a good website that would cover any mount you need. Enjoy
Last edited by fireman-jim; May 18, 2010 at 04:36 PM. Reason: forgot to post the website info
Old May 18, 2010 | 07:06 PM
  #46
PFWiz's Avatar
PFWiz
You do not want to use a phone for dedicated GPS work. No phone, not the Iphone, not the Droid, not the Pre is as good of a GPS as a dedicated GPS.
I use a old Garmin Nuvi 250 on a $10 mount I bought on Ebay. If it rains I wrap it in a baggie with a rubber band. I installed a Kyriakin (sp?) power pod. That way I can charge my phone or my mp3 if I want.
This rig has worked well for last 7500 miles....
Old May 18, 2010 | 11:13 PM
  #47
Driften's Avatar
Driften
One thing to understand about using a cell phone GPS is that it only works when you have cell data service. I have both (iPhone and Android) as well as a TomTom. There are a number of places on trips I did not have data service and no maps on the phones. They are great when data is available since its more up to date then a normal GPS but its a big issue about data service.
Old May 18, 2010 | 11:44 PM
  #48
monenypitof07's Avatar
monenypitof07
Garmin.com ....pick one that suits you.
Old May 19, 2010 | 12:44 AM
  #49
Zenmervolt's Avatar
Zenmervolt
Originally Posted by cruise_carter
I am using this setup, a Garmin etrex Vista HCx with a Ram-mount on the handlebar. The etrex has a micro sd card which I have all of Canada and the USA maps on. It supports turn-by-turn routing.
The etrex is waterproof and runs on AA batteries. I carry some extra Ni-MH batteries and swap out as needed. I get several hours on a freshly charged set with the backlight set on a lower power setting. If travelling, I can get AA batteries cheap at the local Walmart if needed.
Works well for me and didn't have to run extra power cords/wires.
Very similar to what I use. I have a DeLorme PN40 and a RAM mount. The PN40 is waterproof, shockproof and the screen is ridiculously readable in bright sunlight since it's designed for outdoor and hiking use, just like the eTrex. As an added bonus, I can load it up with the hiking trails I want to use and go exploring in the woods with it as well.
I completely agree on the AA batteries too. A charged pair of NiMH are usually good for a full day and even in a worst case scenario I can always pick up a pair of normal AA batteries at the gas station.
I tend to prefer this to using my Droid since, like all cell network-based GPS software, if I'm in areas where I don't have a data signal the Droid's map cache will eventually run out and then I'm stuffed. Since the PN40 has the maps stored in the device itself, it doesn't need a continuous data feed and will work wherever I am.
Old May 19, 2010 | 01:53 AM
  #50
Rocker_C's Avatar
Rocker_C
I got one of these. It will fit any GPS and keep the rain off. http://cgi.ebay.com/GN032-WPCS2-Moto...item35a95228b3
