Help
Old Jun 9, 2010 | 08:49 PM
obonaven's Avatar
obonaven
Originally Posted by oldgeezer
You can also take a Dremel and grind a slot across the head then use a large slotted screwdriver to remove the bolt.
Worked for me last weekend when changing my fluids
Old Jun 9, 2010 | 08:52 PM
stro1965's Avatar
stro1965
I had to drill one off recently, just took a minute and the remaining part spun right out.
Old Jun 9, 2010 | 10:50 PM
davessworks's Avatar
davessworks
drill baby drill
Old Jun 9, 2010 | 11:11 PM
CarbideDude's Avatar
CarbideDude
And if all that fails, buy a new primary cover.
Old Jun 9, 2010 | 11:15 PM
Craig4711a's Avatar
Craig4711a
+1 on dremmel tool slotting the head and use a bladed screwdriver. Worked on 3 of the torx screws I over-tightened. I also learned to use anti-sieze on the heads and threads, and always torque to specs. Good luck, been there done that.... it isn't fun.
Old Jun 10, 2010 | 06:11 PM
bennenrkc's Avatar
bennenrkc
I went out and bought a left hand drill bit set. Started it and it came right out didn't even damage the threads. Thanks for all of the tips. It was just a really frustrating experience. second question where do you find replacement torx heads? I looked in 2 hardware stores and they dont carry torx or a washer of that size? I know it is 1/4-3/4 stainless steel, just can't find one.
Old Jun 11, 2010 | 09:03 AM
oldgeezer's Avatar
oldgeezer
Use allen head screws. Our local hardware store carries chrome ones.
Alamo
Mar 5, 2016 12:30 PM
murd
Dec 9, 2013 09:58 PM
BAKERiSM
Sep 8, 2011 02:25 PM
tjsnoop
Aug 2, 2011 04:04 AM
saltlick
Nov 12, 2006 11:55 PM
