Help
Old Jun 8, 2010 | 09:51 PM
bennenrkc's Avatar
bennenrkc
Default Help
Bolt Number 3 on my Clutch Inspection Cover has a rounded out head. I have tried a extractor with no luck. Any other tips would be greatly apprecieated.
Old Jun 8, 2010 | 10:56 PM
dsiltman's Avatar
dsiltman
I had one do that, I just carefully drilled it till the top came off and take the rest out and the remains will screw out when you get the cover off.
Old Jun 8, 2010 | 10:58 PM
Badmonkey80's Avatar
Badmonkey80
you can also use a chisel, Hit it straight on to make a mark in the head, then angle the chisel and back the bolt out.
Old Jun 9, 2010 | 09:06 AM
oldgeezer's Avatar
oldgeezer
You can also take a Dremel and grind a slot across the head then use a large slotted screwdriver to remove the bolt.
Old Jun 9, 2010 | 10:14 AM
dyna rider's Avatar
dyna rider
Default Stripped Screw
An engraving tool works well...It vibrates the screw loose and you just use the tip to turn what is left of the head counterclockwise. I've also heard a pneumatic engraving tool works better than a electric one.
Old Jun 9, 2010 | 10:40 AM
Brooklyn Devil Dog's Avatar
Brooklyn Devil Dog
Hydraulic engraving tools work much better than pneumatic ones.
Old Jun 9, 2010 | 11:22 AM
Eddy1964's Avatar
Eddy1964
If all else fails drill it out with a left handed drill and retap if necessary. More times than not it comes out with the drill.
Old Jun 9, 2010 | 11:25 AM
texas_speed_freak's Avatar
texas_speed_freak
If its an allen head bolt just take a torx that is a tight fit and tap it into the hole with a hammer. Put a rachet in and should come right out. Whole lot easier than drilling, grinding, etc... Worked many a times for me
Old Jun 9, 2010 | 11:29 AM
96roadking's Avatar
96roadking
Left handed drill would be my first choice, followed by drilling off the head, pull the cover and grab the "stub" with a vise grips.
Old Jun 9, 2010 | 11:52 AM
golfblues's Avatar
golfblues
Jackhammer
