syn3
Old Aug 23, 2006 | 11:09 PM
Mac57's Avatar
Mac57
Default RE: syn3
ORIGINAL: eazy
ORIGINAL: Mac57
Since 30% of the engines cooling is done by the oil that's important.
[sm=confused06.gif]I thought most of the cooling was done by the antifreeze. [sm=icon_stickpoke.gif]
Oh yeah, I almost forgot about the 4-hole Harleys.
Old Aug 23, 2006 | 11:11 PM
Fastlane's Avatar
Fastlane
Default RE: syn3
I have not seen any good specs for harley synthetic. I use Spectro which has higher specs than other oils, especially for temperature. Mobile 1 is good also, but I quit using amsoil after ridding with a few wrenches. I tried synthetic 20-50 in the tranny and took it right back out, I did not like the way it shifted. I say go with a good gear oil and primary oil.
Old Aug 24, 2006 | 11:52 AM
oldgeezer's Avatar
oldgeezer
Default RE: syn3
When I switched from Syn3 to Amsoil / Mobil 1, the engine ran quieter and ran cooler. That's enough science for me.
Old Aug 24, 2006 | 12:01 PM
grumpy irish again's Avatar
grumpy irish again
Default RE: syn3
read several articals on oil and most said mobil 1 was the best
I have been running it for the last 24 thou. and love it only change every
10 thou change filters at no more than 5 thou intervals.
dealer suggestion...
I use reg dino oil in the primary from what I read syn might cause a slip
so just don't take the chance
mobil 1 in tran works great and shifts quit and smooth
[IMG]local://upfiles/5757/5BBCBCAB816845509176FB0461AB7DA6.jpg[/IMG]
Old Aug 24, 2006 | 06:35 PM
pittguy's Avatar
pittguy
Default RE: syn3
Dont run the HD syn in your tranny,go heavier wt.I wouldnt recommend it esp in the new 6speeds.
Old Aug 24, 2006 | 06:37 PM
monkyman's Avatar
monkyman
Default RE: syn3
I think alot of it is personal preference.
Do the New York Yankees suck? To people in boston, yes. To people in Ny, no.
I use SYN3 in primary and in the engine, If you use Mobile1, Amsol, or what ever, it doesn't mean your engine is going to last any longer or shorter than mine.
Changing it regularly and keeping it clean from particulates is what matters. Use an oil designed for your bike and temp range, you'll be fine.
Old Aug 24, 2006 | 06:54 PM
pittguy's Avatar
pittguy
Default RE: syn3
HD will be changing the oil type for the 07 trannys.Bandaid maybe,but its a start.
Old Aug 24, 2006 | 07:50 PM
Gunkholes's Avatar
Gunkholes
Default RE: syn3
ORIGINAL: monkyman
Actually, only to some of the the fans in NYC is it no. Everywhere else, the answer to your question is yes! <g>
Old Aug 24, 2006 | 08:42 PM
pococj's Avatar
pococj
Default RE: syn3
Syn 3 is a good enuff oil. It ain't the best. It ain't even one of the better ones. It's a Group III synthetic, and is not a synthetic blend. A Group III synthetic is actually made from a dino oil base stock.
Worst thing about it is that it is made by Citgo, a wholly owned subsidiary of the state-owned oil company of Venezuela. Why would you want to support that socialist outfit?
Old Aug 24, 2006 | 09:57 PM
1flhtk4me's Avatar
1flhtk4me
Default RE: syn3
Not to defend the Syn 3,but what makes it so bad for the motor?I know that the cost is one issue and not to mention the **** you can get from a dealer from using other than HD 360 or Syn 3.
I know Amsoil has their report,but has anyone run syns(in their own use) long enough to really tell?Have you torn engines apart to compare oils?
This debate goes on and on like the Energizer battery!
