Dyno tune
Old Jun 30, 2010 | 03:08 AM
Damonave's Avatar
Damonave
1st Gear
Question Dyno tune
I have an 09 superglide an I want to bolt on a cool air cleaner that accepts a k&n. Also, my bro has a set of se pipes that I want to slap on too. Soooo...dyno tune? Warranty issues? Wait till warranty runs out?
Teamster Horsemen ftw
Biaggi world sbk ftw
Damonave
Old Jun 30, 2010 | 06:34 AM
Certainteed's Avatar
Certainteed
why bother with a dyno tune? get the sert, datalog, rebuild the map. or let the dealer do a canned download.
dyno tuning is expensive. the net result isnt worth the money cause a sportster will leave you in the dust.
Old Jun 30, 2010 | 07:46 AM
CruzinLow's Avatar
CruzinLow
I must respectfully disagree with your assessment. A proper dyno tune will address areas that a canned map won't.
Put on all the extras - invest in a SEST by all means - and then find a reputable dyno tuner.
Expensive - yes - but well worth the money...
Old Jun 30, 2010 | 10:45 PM
Damonave's Avatar
Damonave
1st Gear
Correct me if im wrong but doesnt the dealer remap the stock ecm during a dyno tune? Why would I buy a sert? Also, how costly is th dyno tuning? And btw, your sporty and my dyna will never be as fast as my r1...
Old Jul 1, 2010 | 05:32 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by Damonave
...Soooo...dyno tune?
You're getting some pretty bad advice here...slide on down to the Tech forums and spend some time in the "tuner" threads.
You have many options and each will yield different results. Some are a notch above snake oil and others will give great results...some might even cause damage.
Ultimately, it's your bike and your decision.
Old Jul 1, 2010 | 07:00 AM
Certainteed
a proper dyno tune will only drain your wallet. learn to use your sert. tune your bike for real world conditions.
my other bike was done the same way racers do it: by data logging and tuning. it romps. no dyno bs needed.
Old Jul 1, 2010 | 03:24 PM
tgshoe's Avatar
tgshoe
A TTS, SERT or SEPST is the only way your ECM can be tuned with a dyno.
Old Jul 1, 2010 | 03:34 PM
RoadKingRon1's Avatar
RoadKingRon1
Damonave
You've got nothing listed to tune?
A dealer can zap your stock ECM, think Stage 1, to account for your breather and pipes but that's about it until you purchase a PC, SERT or SEST.
edit: I see tgshoe beat me to it...
Old Jul 1, 2010 | 04:26 PM
SG 1's Avatar
SG 1
No dyno for me, mostly cause I'm to cheap to do it, and I'm pretty satisfied for now w/my PCIII and canned map from Fuel Moto.
If your gonna do A/C and pipes your gonna need some type of fuel manager or your bike will be running even leaner than it is now.
Old Jul 2, 2010 | 03:03 PM
Damonave's Avatar
Damonave
1st Gear
Thanx for all the posts. Learned alot since my original question. Once i decide on breather and pipes, I"ll be goin withe sert and dyno tune, thanx again.
FDHOG
Nov 7, 2010 09:19 PM
plopper
Aug 28, 2008 10:05 PM
ubreal
Aug 12, 2007 07:44 AM
OIGOFLSTC
Jan 19, 2007 08:13 PM
marty44
35
Nov 28, 2006 04:46 PM
