check engine light/regulator check
Old Jul 7, 2010 | 04:30 PM
vet767's Avatar
vet767
Default check engine light/regulator check
Scenerio, 07 street bob. Ignition on check engine light does its thing A few seconds after it goes out it comes back on for a few seconds then goes out and stays out. Go down the road and the light comes back on. Stop, shut it down turn it back on same thing. Continues so since we have to get home dennis ignores the light. Battery light comes on We stop. no start battery is dead. Jump the bike and get home. Only dtc is low battery voltage. Charged battery checks out good. I suspect voltage regulator, only problem is that HD manual does not tell you how to static test the VR on an 07. Says you need the electrical manual. My 99 sporty did the same thing, (minus the computer chit since it doesn't have lights like that). That manual tells you how to static test the regulator. Anyone know how to test it on the newer models. And yes we have checked and cleaned all battery cable connections. At this time the battery is charged and reinstalled. Ignition on you get the check engine light. Goes out and doesn't come back on. Start the bike, all is good. Somehow it might be cured but we would all feel better if we coud check the vr. Might be that the check engine light comes on before the system records low battery voltage condition. Any thoughts would be appreciated as well as steps to static test the VR Thanks
vet767
Jan 22, 2020 09:21 PM
thebandito73@gmail.com
Jun 10, 2017 12:41 PM
labou1
Aug 20, 2014 05:56 PM
jrdfatboy
Jul 30, 2012 06:33 AM
Astro
Oct 22, 2010 05:49 AM
