Highest mileage Harleys
Old Jul 8, 2010 | 10:26 AM
jellyrug's Avatar
jellyrug
Default Highest mileage Harleys
Who has the higherst mileage on his Hog over here and what did you have to do to keep it running?
Old Jul 8, 2010 | 10:49 AM
DanD's Avatar
DanD
over where?
Old Jul 8, 2010 | 11:32 AM
Scooterzs's Avatar
Scooterzs
2nd Gear
94' Sporty "Glydster" has about 120K(about, because speedo hasn't always worked-replaced speedo 6 times) Only had OEM style with first speedo, then went to aftermarket style on last 5. At 100K did a complete rebuild-custom because I started having alot of problems with it running badly. Everything I checked before and during teardown, though was not failing. Upon starting to put eveything back together, I was in the process of building motor and when I got the (original)ignition sensor out of parts box, I found that the sealant on the sensor itself had liquified and all had run out(looked OK when I took motor apart), I realised then, that was the the culprit of why it was running like crap. But, during 8 years of riding, I changed clutch release bearing 3 times, clutch plates once @ 50K, cylinder base gasket went bad at about 75K, stator 3 times(1st time I got aftermarket and it failed withing 3 mos.,(some things have to be OEM for reliability)When I first got bike with less than 1500 miles, rocker cover base gasket was leaking, did rocker gasket set 4 times during 8 yrs., drive belt 3 times, ALOT of tires, a few batteries and alot of oil changes.
NOTE: When I took motor apart, I found that trans gears had "0" wear marks and crankshaft/connecting rods had no play or signs of fatigue for 100K-used nothing but Valvoline 20/50, SAE50 during hot months.
85' FLHTP has 42K. I have replaced stator, starter, starter solenoid, coil, ignition sensor, ALL circuit breakers(3-15A & 1-30A), main battery leads, rear tire, battery, clutch adjuster plate, trans. main shaft seal.
Old Jul 8, 2010 | 01:42 PM
TequilaJohn's Avatar
TequilaJohn
My '05 Deluxe has just over 66k on it, and has had nothing but regular maintenance, and the cam chain tensioners replaced at about 45k.
Old Jul 8, 2010 | 01:51 PM
bwana1's Avatar
bwana1
'06 Ultra has 86,600 miles, will be making an Alaska trip next June and was last serviced at a dealer at 1,000 miles. Biggest expense, tires and gas. Biggest nuisance, I've replaced or repaired six fairing brackets.
Bwana
Old Jul 8, 2010 | 01:53 PM
RidemyEVO's Avatar
RidemyEVO
I had 136000 km on my 89 flhtp before I decided to rebuild it last winter for what appears now to be no apparent needed reason.
Go EVO Go.
Old Jul 8, 2010 | 02:26 PM
FLST rider's Avatar
FLST rider
130k on my Heritage. Normal maintenance and bolt on type issues.
Old Jul 8, 2010 | 02:33 PM
joe.1955's Avatar
joe.1955
87K on an '08 Wide Glide.
Regular maintenance every 5K, still running strong.
Old Jul 8, 2010 | 05:20 PM
ptl203's Avatar
ptl203
3,600 miles on my 2010 RG...does that take 3rd place?
Old Jul 8, 2010 | 05:29 PM
BobStreetBob's Avatar
BobStreetBob
Only if you did it in 2 days.
I'm at 63 or 64K on the 06. Still going strong and hope to double or quadruple that before anything major gets done.....cause I'm po'
