Battery Replacement?
Old Jul 12, 2010 | 07:25 AM
Jerry1834's Avatar
Jerry1834
Default Battery Replacement?
OK...going to do a load test on my 09 battery this morning and may need to replace it....What would you go with (Brand)? My friend says Yuasa makes most of the batteries today. I can get and Inter-state at cost but in the old days they were just fair (cheap) type. Suggestions?????
Thanks for your input.....Jerry
Old Jul 12, 2010 | 07:34 AM
dawg's Avatar
dawg
If you maintained it properly it would be still under warranty being it's an 09 bike. I'd stick with the HD 66010-97C. If not, get the Deka ETX30L which is the same as the HD
Old Jul 12, 2010 | 07:35 AM
geezer glide 56's Avatar
geezer glide 56
Why do you think your 09 needs a battery?...You might want to check your connections...Battery cables...Charging system...It would be unusual for your battery to be dead already without some other issues going on.
Old Jul 12, 2010 | 07:43 AM
spiritwarrior's Avatar
spiritwarrior
I would borrow someones, trickle charger and try that for a day before replacing the battery. Unless you left it set for a year the battery should still be good. Most often as someone has already noted, check you battery cable connections and make sure they are clean and the bolts are tight.
If you have to replace it, the glassmat batteries, last longer than a normal battery and don't discharge as fast. That is a method of construction not a battery brand.
Old Jul 12, 2010 | 07:49 AM
Jerry1834's Avatar
Jerry1834
First, well maintained ...cabels OK...warranty is up (figures..almost 40k on her)....Stater sounds like its coming throught the otherside sometimes....Put a charger on it last night and took the charge OK...Just figured I get some input on the brands....HD stock is OK with me but I wanted to put it out there in a question.
Old Jul 12, 2010 | 07:52 AM
huffhuff's Avatar
huffhuff
i found on one of the local police bikes that the cables were installed such that the weight of the cables were allowing them to loosen under vibration. they need to be oriented so that the weight of the cables pulls down on the fasteners to keep them tight.
Old Jul 12, 2010 | 04:57 PM
Jerry1834's Avatar
Jerry1834
OK...good news... battery OK but need a new starter and its covered under warranty seems I have 7 days left till 2 years are up. The HD shop gave me bum info when I checked the first time but the salesman got me the right info...Lucky!
WindDamage
May 21, 2013 11:19 PM
horsepower
Oct 14, 2010 11:53 AM
golfblues
Aug 29, 2010 11:54 PM
EricW
Nov 29, 2009 03:38 PM
Lopoetve
Sep 11, 2009 07:28 AM
