Clutch Adjustment Problem
Old Jul 26, 2010 | 10:05 AM
hoethree's Avatar
hoethree
Unhappy Clutch Adjustment Problem
Not getting any help in the Mechanical Sections, sorry to double post.
"I hate to post yet ANOTHER thread about adjusting the clutch and I have searched the other threads but I still have a question unanswered.
Yesterday I adjusted my clutch according to the exact directions in the service manual. When I attempted to start the bike, in neutral with the clutch lever pulled all the way back, the bike wants to lurch forward when I hit the starter. So something aint right. Is this something to do with how I adjusted the adjuster nut in the clutch pack or is this more to do with where I have the cable adjusted? Right now the cable is adjusted so the clutch lever is nice and snug with just the right amount of freeplay per the service manual. Suggestions? Many thanks!"
Old Jul 26, 2010 | 10:09 AM
1931jamesw's Avatar
1931jamesw
If it's still pulling when you have the lever squeezed in, the adjuster screw is probably turned too far out. Start the whole process over again including the cable adjustment and be certain that the bike has cooled to room temp before adjusting it.
Old Jul 26, 2010 | 10:12 AM
Scorpion07's Avatar
Scorpion07
Did you depress the lever 3 times per the manual instructions to seat the rod at the cam? Not much can go wrong other then that.
Old Jul 26, 2010 | 10:17 AM
tlb's Avatar
tlb
you should not be starting it in gear. your clutch plates are stuck together. put in neutral and start the bike, shift into gear and ride. If it jumps with the motor running, when you shift it into gear, you did something wrong. If it does not then it is adjusted correctly.
Old Jul 26, 2010 | 10:35 AM
CroK's Avatar
CroK
There should be NO LURCH when starting in neutral. It is normal, with a properly adjusted clutch, to have a small amount of lurch before the clutch plates disengage WHILE IN ANY GEAR. I would suggest doing as jamesw stated. Start over...
When you adjust the clutch screw and locking nut on the clutch itself, make sure to turn the screw in until you feel resistance, then back off half a turn. Then run the screw in again until you feel resistance, and once again back off half turn. You may see that the clutch screw turns in a little further each time, until all the play is taken up and it no longer moves in further on the next turn. Once you notice there is no further movement of the point of engagement, then back off the screw 1/2-1 full turn and tighten the lock nut. All of this is done while the cable adjuster has been fully collapsed, and absolutely no resistance felt when you depress the clutch lever.
Once you have the center clutch screw and lock nut adjusted, then adjust the clutch cable adjuster according to the book. Make certain you depress the clutch lever several times between each adjustment to the clutch cable adjuster, to alieve any slack in the cable.
If you still have any lurching while in starting the bike in gear, I'd then look at the clutch shift arm adjustment on the left side of the tranny behind the primary. In neutral there should be no resistance as the transmission itself has disengaged the gears.
Old Jul 26, 2010 | 10:42 AM
hoethree's Avatar
hoethree
Guys,
The bike is in NEUTRAL, clutch lever pulled in all the way back, bike lurches when I hit starter. I did it by the book including squeezing the clutch lever three times to seat the rod at the cam. I will repeat the process tonight. Will take 1931jamesw's advice. If the adjuster nut is to loose (backed out to far) exactly what does tightening or loosing do? Does the adjustment here affect where the clutch engages/disengages if the cable is properly adjusted? I just cant seem to get the hang of this.
Old Jul 26, 2010 | 11:15 AM
1931jamesw's Avatar
1931jamesw
Yes, the adjuster screw dictates where the clutch engages. The farther it is backed out, the sooner it engages. The farther in it is, the later (lever father out) it engages.
Joe Diver's Avatar
Joe Diver
Originally Posted by CroK
....All of this is done while the cable adjuster has been fully collapsed, and absolutely no resistance felt when you depress the clutch lever.....
Then how do you activate the clutch 3 times to seat the *****?
Old Jul 26, 2010 | 11:18 AM
HOG_0308's Avatar
HOG_0308
+1
my 08 Ultra will do the same thing if i start the bike in gear. start the bike in neutral
Old Jul 26, 2010 | 11:42 AM
wlbowers's Avatar
wlbowers
You have to be careful when you tighten the locknut not to let the screw turn.
That was my problem until I found the right combination of tools.
