40 psi solo a bit squirrely
Old Jul 29, 2010 | 03:31 AM
sniper77's Avatar
sniper77
Originally Posted by Soft06
I run the Dunlop 200/55R17 on my 06 Standard and the sidewall listing for MAX PSI is 42PSI.
There is no way I should run less then 36-38PSI, single ,,,BTW 2-up I run 40PSI
So read your sidewallls.....and remember that is M A X PSI pressure
I suppose if you weigh 400+ lbs running 36 psi might be okay, as long as you don't care about tire life.
It's funny people think they need so much psi in a tire yet can't figure out why they only get 5,6, or 7k out of it, lol.
Old Jul 29, 2010 | 07:14 AM
fxdx-fly-by's Avatar
fxdx-fly-by
i have 35 in mine does good solo owning corners or two up..
Old Jul 29, 2010 | 07:24 AM
sunrise rider's Avatar
sunrise rider
Stock Dunlops, run 36lb both front and rear all the time.. If I run less it doesn't handle as well.
Old Jul 29, 2010 | 08:06 AM
XL50#674's Avatar
XL50#674
I run my rear at about 40 at all times and I like it, but i'm use to it. Now when my my front was down to about 32 the one day that sucked! Bar slap like crazy.
Old Jul 29, 2010 | 08:08 AM
FastHoss's Avatar
FastHoss
Maybe that's why I don't get good mileage out of rear tires,I follow what Harley says to put in.
Old Jul 29, 2010 | 08:16 AM
cadman311's Avatar
cadman311
Hard tires spin good and soft tires grip the road. To much air turn your tire hard with less grip. 40 pounds of air or more will spin my tires. And with 9 pounds of air will do Wheelie most all day. Don't run the roads with that low air pressure as your tires may run off.
Old Jul 29, 2010 | 08:22 AM
Gonzy's Avatar
Gonzy
Gonzy
Originally Posted by dh2683
Thats not what the mfg. tag says on the frame for tire inflation.
I run 40 in the rear & 38 in the front weather I am 1 or 2up.
Stock Dunlops on a RKC
Same here. After my last service I checked my front tire pressure, someone had bumped the pressure up to 44 lbs! I took it down to 38 and the handling was way better. 40 lbs in the rear seems to work pretty good too.
Old Jul 29, 2010 | 09:08 AM
Soft06's Avatar
Soft06
You run what you want, and I'll run what I want.
It's been my experience that running to low will results in cupping.
Old Jul 29, 2010 | 09:31 AM
FastHoss's Avatar
FastHoss
The Harley manuel with my bike says 36 front 38 rear solo,40 two up on rear
Old Jul 29, 2010 | 10:35 AM
tomt's Avatar
tomt
My owner's manual with the stock Dunlops says, Solo front, 30 PSI 2 up, 30 PSI. Solo rear, 36 PSI, 2 up, 40 PSI.
I changed my front to a 21" Metzler. 38 PSI per Metzler's web site.
