QUICK! help - no start
Old Jul 29, 2010 | 08:51 PM
skydvr's Avatar
skydvr
Default QUICK! help - no start
01 Fatboy. went to start the bike up. engine start on, depress the starter button. Big clunking sound on the left side. No engine turnover. Just that rapid click. Oil light is on, and yes oil was low. I filled back and same thing.
any ideas?
Old Jul 29, 2010 | 09:11 PM
1skrewsloose's Avatar
1skrewsloose
Don't really think oil level would have much to do with it. Sounds more like an electrical issue. Bad/corroded connections, at the battery, etc, or weak battery. Did you try to jump start it?
Old Jul 29, 2010 | 09:13 PM
golfblues's Avatar
golfblues
Loose connection or a dead battery.
Old Jul 29, 2010 | 09:16 PM
soft 02's Avatar
soft 02
+1 golfblues!!
soft 02's Avatar
soft 02
+1 for kick starters!
Old Jul 29, 2010 | 09:30 PM
skydvr's Avatar
skydvr
No dead battery. connections are spotless. batttery is new in april 2010. It is sitting the battery tender now, but did not jump it, per se.
Its gotta be mechanical. What engages just as the engine turns over? I can feel it in my grind in the seat of my pants. Sounds horrific.
Old Jul 29, 2010 | 09:33 PM
soft 02's Avatar
soft 02
flat spot in ring gear?
golfblues's Avatar
golfblues
Clicking is usually a dead battery. Even though it's fairly new it could have a bad cell. If you have a meter do a load test after its fully charged.
Old Jul 29, 2010 | 09:34 PM
soft 02's Avatar
soft 02
Harley starters are known for bad "over run" clutches aka sprag clutches. I've replaced 3 on my 07.
Old Jul 29, 2010 | 09:42 PM
1skrewsloose
Maybe check the connections at the starter solenoid, if you got juice at the battery, its not making it to the starter, sounds like. Check grounds too.
