Leaky carb.....
Old Aug 5, 2010 | 06:00 PM
PktChg's Avatar
PktChg
Default Leaky carb.....
I have an '01 XL1200C that leaks from the carb a bit. I know this is kinda standard but, how much is too much?? Is there a way to stop it?
Old Aug 5, 2010 | 06:16 PM
cHarley's Avatar
cHarley
While it may be normal for some older Harleys to drip some oil, leaking gas is never acceptable unless you're looking to cook something.
If the carb is original it's over due for a rebuild. Rebuild kits are cheap, about $15.00, and it's an easy job. You can find a rebuild kit HERE.
Old Aug 5, 2010 | 08:05 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 on the rebuild, it's very easy to take the float bowl off and spray some carb cleaner up and around the float, might be something causing the float needle to stick. Protect the fuel tank.
Old Aug 5, 2010 | 11:58 PM
PktChg's Avatar
PktChg
My bad.......I didn't clarify the leak. it's oil not gas.
Old Aug 6, 2010 | 12:05 AM
Mal74's Avatar
Mal74
Where's the oil leak?
KISS
Old Aug 6, 2010 | 06:53 AM
carlgrover's Avatar
carlgrover
So it's leaking oil from the carb?
Old Aug 8, 2010 | 04:10 PM
PktChg's Avatar
PktChg
That's what it looks like. I can drive for about 30 mi. and will see a few drops of what looks like oil from the bottom of the cover. it doesn't smell of gas so what could it be??
Old Aug 8, 2010 | 05:24 PM
Sgt. Fury's Avatar
Sgt. Fury
Oil's overfilled and pushing thru the breather.
Maughanaj
Sep 23, 2017 01:30 PM
smittyhasahog
Jun 12, 2014 06:17 PM
straightleg
Exhaust System Topics
Jul 10, 2013 07:14 AM
randybecker
Sep 14, 2011 11:29 PM
Warlord
Mar 9, 2010 05:51 PM
