El Choppo
I'd do some research online to get a feel for what 's involved if you haven't done anything similar before for starters . I've seen some good stuff showing frames being worked . You still want an insight after PM me or an email I've done mild to wild in a proper shop and the back yard poor broke biker method .
However, the one frame I "chopped" was in the mid '70s, and it was done like this:
1) Cut through 90% of the neck from right behind the stem, up through the casting. Leave about 1/2" of the casting intact.
2) Heat the casting in the area of the cut red hot with a torch.
3) Using something like a Gandy stuck down through the neck bend it out to the desired angle. Pay particular attention to not twisting it left or right. Use a protractor to check for the desired angle.
4) Fill the cut as well as you can with weld. I heard of people cutting a small piece of iron to fit the notch, but I didn't do it that way.
5) Weld gussets made from 1/8" to 3/16" stock to each side. Make sure you get a full circumference weld.
As I said, from the vantage point of 40 years this seems like a suicidal way to modify a frame. but it worked for me. Assuming you're going to use a rigid, you can buy a custom frame with any dimensions you want much cheaper than buying any stock HD rigid frame.
With a few tricks added for proper alignment and square that's pretty much the " Backyard Poor Broke Biker " method . Frame jigs are the way to go if available but with a decent table , clamps and couple of round bars of the proper size you can do good clean job and keep it straight . It's all in the lay out & welding work . There's some math involved and knowing how to center line and square steel , basic Millwright / fabricator skills . You need good welding skills also to keep things square . Most guys start running long beads on one side at a time , big no no doing it this way a neck will pull itself 1/4" + off and you won't see it till done .
" Fill the cut as well as you can with weld " works for a small gap , 1/8" max , anything wider fit solid gussets in and weld up . Filling a big gap with welds heats up the area WAY too much cast steel will warp and the base metal actually weaken badly . Ever seen a piece of cheap angle iron break after being welded ? same thing .
Not knocking any body's advice here . It's part of what I do for a living I can't help it , too many clueless apprentices over the yrs .
Every body has heard of Paughco frames ? Old name in the parts world . I had to return a frame had a tweaked neck off the truck, went their plant in Carson City Nv . No joking or fudging their frame manufacturing plant is a wooden pole barn add on , dirt floored and the frame jigs were 2" tubing welded to old truck rims with 3/4" water pipe gubber on & visegrips to hold parts . And we pay money for stuff that is built using this , Scary isn't it ...
Sorry if it's a bit long but this isn't something simple to explain . The bike in the second pic was done 28 yrs ago in the garage with real basic tools ( hacksaw
& buzz box monkey wards welder ) add on hardtail section & some neck work
