valve guide and guide seats
Old Aug 19, 2010 | 01:43 PM
EW1959's Avatar
EW1959
Default valve guide and guide seats
Iam one of the ones that asks about oil all the time. I have finally got the attention of the Harley tech about the oil loss. He thinks it may be passing through the oil guides seats into the primary. He said he would drain the primary to see if there is more fluid than normal. If it is true what should be my actions toward dealership since the bike only has 4500 miles on it. It is under warrenty but once you take the heads off to start digging around that is not good for a customers view.
Old Aug 19, 2010 | 02:56 PM
RHPAW's Avatar
RHPAW
If it was getting past the guides or the seats, your engine would smoke.
I don't know how it could get into the primary unless there is some leakage through the bottom end (think compensator area). If your H-D tech thinks it's from the guides or valve seats, you need a new tech.
Old Aug 19, 2010 | 03:02 PM
prodrag1320's Avatar
prodrag1320
your HD tech actully suggested the oil is getting past the VALVE guides and getting into the primary????time for him to start looking for a new job doing something besides working on bikes!!
Old Aug 19, 2010 | 03:07 PM
FLYING's Avatar
FLYING
I have been wrenching a long time and if the guides were bad you would have blue smoke on start-up with a cold engine.If you do not have that,I would think there is no valve guide problem.I think a trip to a second dealer for a skilled opinion might be in order!
Old Aug 19, 2010 | 03:36 PM
EW1959's Avatar
EW1959
All I know is that is's going somewhere and I'm tired of looking. No leaks on ground,not smoking or comming out of the breather. I give up, out of ideas.
Old Aug 20, 2010 | 01:59 AM
oct1949's Avatar
oct1949
Go to another dealer and have it checked out....If Ur still under warranty U shouldn't have to look for it Ur self anyway.
U didn't say how much U loosing.... like 1 qt every 500 miles??? or 8ozs in 5000 miles???
Old Aug 20, 2010 | 07:11 AM
cHarley's Avatar
cHarley
Loss of oil from leaky valve guide seals can almost always be seen from the exhaust pipe(s), but only during decel. With the bike on the jiffy, rev the motor up high and then snap the throttle closed. As the motor RPMs wind down you should see wisps of smoke from one or both pipes if that's the problem.
Old Aug 20, 2010 | 08:10 AM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
if you still have stock exhaust on bike or just stock header pipes, the cayt there will stop the oil smoke from going out the exhaust, (small amounts of oil get consumed within the cayt itself) so you might not see the oil smoke, it does plug cayt after a time, but thats a different subject, very good chance guides are the problem of your oil loss, rings not seating properly can also be part of it. getting into the primary takes a big hole in the head of that guy who told you that. there is no possible path that oil can get in from the motor, unless the crank seal fails and even then you will not get all that much oil there, not enough to measure, to say guides are a problem, find another dealer quick! document oil losses with mileage, dates, and amounts of oil added, and insist on action, if its not on the ground, its out the pipes and that can only mean the top end is giving it up
Old Aug 20, 2010 | 10:55 AM
EW1959's Avatar
EW1959
Half a quart to a quart every 800-1000 miles. I don't understand all the inner workings of the motor. I've had to add 1 1/2 quarts in the last 2k miles. If it's not smoking or leaking I have no clue adn I guess neither does the Harley tech of 23 years.
Old Aug 20, 2010 | 11:26 AM
RoadKingRon1's Avatar
RoadKingRon1
Did you say what kind of bike you have?
My '05 RK had the dreaded vavle stem seal problem. It smoked on decel and used quite a bit of oil. It got to the point carbon kept the valve from completely closing.
I gotta agree with everyone else, I don't see how oil is getting past the seal and guide into the primary.
