Dyna vs Softail
Old Sep 12, 2010 | 09:40 AM
  #81
FroggyFatBoy's Avatar
FroggyFatBoy
pretty much, what you lose on one end, you'll gain on the other..
i think a accurate dyno would show the difference, or they wouldn't be able to tout a HP increase with a lighter flywheel..
i can't remember the name of the old farm tractor i saw a few weeks back.. it had a huge 3' heavy cast iron flywheel on it to start it.. you grabbed the top and got it spinning, which took some muscle, but once spinning it spun the crank with ease.
Old Sep 12, 2010 | 09:47 AM
  #82
schumacher's Avatar
schumacher
Originally Posted by 32vld
They are.
Sportster's are down sized to fit girls. Hence sportster's/girlster's are girl's bikes.
no, Fatboys are girls bikes
Old Sep 12, 2010 | 09:49 AM
  #83
pococj's Avatar
pococj
I wonder if not feeling the torque difference between the A & B motors falls into the same category as not feeling the torque loss caused by running drag pipes? I have often had people who swapped stock pipes out for open pipes tell me they couldn't feel the difference. Self observation when I swapped pipes out - I could definitely feel the difference, but simply whacked the throttle a little harder to compensate. If someone regularly swaps between A & B motored bikes, would the same scenario apply? Probably.
Old Sep 12, 2010 | 09:54 AM
  #84
pococj's Avatar
pococj
(Snip a bit)
Nah, y'all both are wrong. Dyna's are girlie-bikes 'cuz Dyna is a girlie name.
Old Sep 12, 2010 | 09:55 AM
  #85
srshaw's Avatar
srshaw
I would think a Dyna may feel a bit slicker when revving in neutral, but once running in gear, I can't see how the balancer will affect performance that much. These bikes are over 300kg. Thats what going to stop them accelerating quickly.
Old Sep 12, 2010 | 09:58 AM
  #86
harleytom's Avatar
harleytom
Be glad its a harley.. Get on it and ride. But ride safe
Old Sep 12, 2010 | 10:13 AM
  #87
32vld's Avatar
32vld
I have to admit that the Softail Deluxe is one beautiful bike. The forward controls are not too forward for me. At 5'9" the seat and floor boards fit me perfect.
The B motor turns me off to buying one. It's not because there is a small loss in power. I want vibrations to be at a minimum.
I also don't want an engine that has a bunch of expensive parts that can wear out and have to be replaced that aren't needed in the first place for an engine to run. Just adds weight and expense. Those parts don't increase power, or improve mpg.
So for the time I will continue to ride my son's girlst...... err I ment Nightster, until I can afford another Super Glide.
That was the bike for me when it came out in 1972 with a normal rear fender, and when I bought a 1978 80 cu in Super Glide.
As many before me I sold it because I needed the money. Glad I have my son's bike to use.
To ride I would even sink down as low as to ride one of them new Indians. Wish I could even afford a Honda Rebel just to go riding with my son.
However I draw the line with them Victory's.
Old Sep 12, 2010 | 10:16 AM
  #88
schumacher's Avatar
schumacher
yeh....me too
Old Sep 12, 2010 | 10:40 AM
  #89
32vld's Avatar
32vld
yeh....me too
I knew you would not let that pass.
Old Sep 12, 2010 | 10:43 AM
  #90
191185's Avatar
191185
OK, so on the first page, you call the Softails a "poser bike" then come to find out you don't even own a harley ? oh, but you "used too" back in the day ? makes sense now ... just another person on the interenet, that knows everything there is to know about everything, but doesn't even ride. ..
And then you draw the line at Victory's ? does that mean you will never "stoop that low" ? why are they poser harleys ?
