Tap and die set
Old Sep 14, 2010 | 08:40 PM
PktChg's Avatar
PktChg
Default Tap and die set
My apologies if this is out of place but I'm in a pickle...... Somehow I crossed the threads on the top bolt of my front exhaust port and it WILL NOT take a bolt. I cannot easily get it out to put into a vise so, can I easily get to it otherwise?? I have limited tools and limited brains.........ANY suggestions would be great.
Thanks all.
Old Sep 14, 2010 | 09:16 PM
DaddyKnuck's Avatar
DaddyKnuck
You can run a die up it to restore the threads. If they're really chewed up replace the stud. Should be able to find a replacement at any auto parts store. Best way to pull a stud you're going to replace is with vice grips.
Old Sep 14, 2010 | 09:17 PM
oldairboater's Avatar
oldairboater
Isn't that a stud bolt? There is a special tool for pulling stud bolts. It is compact enough to fit in the space between the front jug and down tube.
Old Sep 14, 2010 | 09:33 PM
PktChg's Avatar
PktChg
Is that a normal die set or a specialty set???
Old Sep 14, 2010 | 09:45 PM
DaddyKnuck's Avatar
DaddyKnuck
Should be in a standard set.
brad75raiders
EVO
28
Mar 1, 2022 10:01 PM
willryder
Wheels/Tires
Jan 11, 2019 09:52 PM
rdunkin1986
May 1, 2017 10:53 PM
pt4u2nv
Custom Models
Sep 23, 2009 02:06 PM
SpaceBrain
Jun 1, 2008 09:27 PM
