Screaming Eagle head problem
Old Oct 7, 2010 | 05:50 PM
Soldier of Misfortune's Avatar
6th Gear
Default Screaming Eagle head problem
I have a 2001 sortster engine that I put heads on. The problem I am having is that the s&s intake manifold that i have wont bolt on to the rear head but it will bolt on the front head. The bolt pattern on the rear head is much larger. The bottom hole is about an inch off. The front is perfect. The guy I bought the heads off of told me they were for 2000 and up sporty models. I could use some help with eaither a part number or just some advice. I know I can take the heads off and drill and tap a new hole in the rear jug but I was just wondering if I am missing something. I have been to the dealerships and talked to my buddies. Nobody has an answer for me.
Old Oct 7, 2010 | 06:11 PM
Tom84FXST's Avatar
Tom84FXST
You should post pictures...it would make it easier to figure out. From your description, it almost sounds like you have 2 front heads and the bolt pattern that doesn't fit is actually for the exhaust. Post some pics!!!!
Old Oct 7, 2010 | 09:04 PM
6th Gear
Old Oct 7, 2010 | 09:06 PM
6th Gear
I think after doing some research what I have is a set up for fuel injection...now I need to figure out how I'm going to put a carb on it. I might be drilling and tapping.
Old Oct 7, 2010 | 09:49 PM
hogman1999's Avatar
hogman1999
Stage II
heads should be marked front or rear. se catalog is available on line for download to check if you have the right heads.
Old Oct 7, 2010 | 10:00 PM
cHarley's Avatar
cHarley
You didn't say what motor you have, 883 or 1200. For what it's worth, 2004 and up 1200's have Buell Thunderstorm heads.
Old Oct 8, 2010 | 06:33 AM
6th Gear
The heads are marked front and rear. They are installed in the correct place. The engine is a 1200 2001 sportster...and they are sreaming eagle heads not buell heads.
Old Oct 8, 2010 | 07:19 AM
shortride's Avatar
shortride
Can the rear cylinder intake flange be replaced?
Old Oct 8, 2010 | 07:44 AM
geezer glide 56's Avatar
geezer glide 56
The intake flanges are location specific...They should be stamped f front...r rear.
GSlone
Mar 18, 2024 04:19 PM
swags63
Classic Harley Parts
Jan 12, 2024 05:57 PM
Rabbito
EVO
Mar 31, 2014 01:36 PM
1982DSB
Jan 14, 2013 07:28 PM
Island Hog
May 2, 2012 03:51 PM
