HD security
IF you do own it, the information is listed in the owners manual. Simple procedure to look up.
Another way... if you are legit, visit your local dealer. They will provide you the correct information to do this procedure. And I would also bring your registration w/ you as well.
Please no one provide the info on the forum to this person. Sorry ace but 37 years as LEO before retiring makes me very suspicious about you and your SINGLE post
To start your bike using the security code (you must know the code if you dont have your FOB).
But if you have the FOB you can change the code at anytime even if you dont know the pin, read below.
the code is a 5 digit number 1-9
disarming the alarm: (With the known pin)
Turn on the ignition, (do not shake the bike or turn the stearing or raise it off its stand) quickly hold down both turn signals until the Key Icon flashes at a high rate in the odemeter window (5 flashes).
enter first digit of your pin by pushing the left turn signal until the first digit shows in the odometer, once the correct digit is reached, press the right turn signal 1 time to store it.
enter second digit of your pin by pushing the left turn signal until the second digit shows in the odemeter, once the correct digit is reached, press the right turn signal 1 time to store it.
continue doing this until you have entered all 5 digits of your pin. once you have entered the 5th digit and stored it by hitting the right turn signal once, the key icon will stop flashing, you can now mount, start and ride your bike.
if you do not know your pin number, but you have a FOB, you can change the number right now. FOB must be present to perform pin change.
select a number with 5 digits 1-9 that you can remember and nobody else will know. write this number down on your card.
Turn the ignition ON OFF ON OFF ON
Press left turn signal switch 3 times
Press right turn signal 1 time and release
Turn signals will flash 3 times and The current pin number will appear in the odometer, the first digit will be flashing.
enter the first new digit of your new pin by pressing the left turn signal X amount of times. once happy with the digit, press and release right turn signal.
enter the second new digit of your new pin by pressing the left turn signal X amount of times. once happy with the digit, press and release right turn signal.
After you enter the 5th digit and store it by pressing and releasing the right signal button, turn the ignition off before the security system rearms itself, This stores the new number, you have now changed your pin.
its fairly easy to do.
