Bike layer down on me on my first trip to town
Old Oct 20, 2010 | 10:25 AM
Kowan's Avatar
Kowan
My guess is the inline filter's plastic was touching the engine and melted.
Stock, the line would have a plastic loom heatshield where it passes down through between the cylinders.
Harley uses a guide attached to the carb the line runs through to keep it centered between the cylinders.
Old Oct 20, 2010 | 11:52 AM
piasspj's Avatar
piasspj
Check out your local auto parts stores or small engine repair shops. They probably have metal or glass in line filters (I like the glass ones).
Be sure to locate it so it doesn't touch anything that could damage it.
Old Oct 20, 2010 | 12:32 PM
champ198's Avatar
champ198
The line dont have anything around it as far as loom goes but ill take a closer look at it in the next few days and see what i can figure out on it to make it right
Old Oct 20, 2010 | 03:41 PM
yljkt's Avatar
yljkt
Can we get an idea of the year and model of this potential flamethrower on wheels?
Old Oct 20, 2010 | 04:03 PM
champ198's Avatar
champ198
it is a 1994 Sportster 883 hugger
Old Oct 20, 2010 | 04:27 PM
yljkt's Avatar
yljkt
There should be a metal loop off the back side of the carb that the fuel line passes thru to keep it centered between the cylinders. If thats not there [no idea if this bike is stock or the carb] I would get a metal inline filter and figure out a way to keep it and the fuel line from contacting anything. I have seen guys use zip ties under the tank and hang the line. Outside of being run over by a dump truck, the last thing you want is to be blasting down the road and have a fire. It can happen. And before you get stopped, you and the bike can be on fire. Gas+hot exhaust+ wind=disaster.
Old Oct 20, 2010 | 04:34 PM
champ198's Avatar
champ198
ok ill take a closer look at it before i ride it again much and see what i can come up with
Old Oct 20, 2010 | 04:43 PM
schumacher's Avatar
schumacher
just use common sense on the line routing and filter placement, you'll be fine.
Old Oct 20, 2010 | 07:27 PM
yljkt's Avatar
yljkt
hard to answer your questions with that avatar lol
Road Star
Oct 8, 2016 09:49 PM
btsom
May 10, 2016 08:30 PM
petewood70
EVO
Aug 2, 2010 11:47 AM
SC-Longhair
Apr 1, 2010 12:32 PM
Milwaukee Steal
Oct 20, 2007 07:37 PM
