Backing off the throttle and slowing down are the same, no? You don't want to slam the front wheel into a two inch piece of blacktop.
You should also lean back to take as much weight as possible off the front end. Coming off the throttle should also help do this.
My pre-Harley training was to get up off the seat. This would move the weight down on the bike and let me use my legs in addition to the bike's suspension when hitting. I think this is fine on a Harley if you can get up off the seat - it can typically be difficult if not impossible to get off the seat on a bike with forward controls.
ORIGINAL: hd lady
Oh yah, I forgot that area is pretty messed up too. So did ya'll miss me on the ride? We ended up getting a lot of rain a little later in the day but ya'll probably missed it.
Got hit a little. But was actually in between 2 systems so wet just a few miles.
ORIGINAL: nine11c2
You are correct on front wheel load, but getting ON the throttle would accomplish that, not decelerating. Remember the physics of energy transfer. When accelerating, weight and energy shifts rearward, and with enough of that the front wheel lifts completely off the ground. When you lift off the throttle, you are no longer transfering energy rearward, so it seems as if you are surging forward (when really just achieving equilibrium). But that does put more weight on the front.
You are right Grunt. I knew this was wrong as soon as I typed it. Accelerate - rearward weight shift, brake forward. You want to come off the throttle to slow down and keep the bike as neutral/stable as possible. My experience on big bumps, off the throttle to keep the bike as NEUTRAL as possible (very similar to when you come across sand - yes not really to put weight back) and lean back or step off seat as appropriate. You don't want to drive either wheel hard into a bump under acceleration...
From my MSF course, we learned to blip the throttle a split second before front tire hits (road debris, edge of new road, etc) and then roll off instantly for rear tire to cross. Haven't really had a chance to do it on the road, but was great for driving over 2x4's multiple times. I believe rolling off the throttle after front tire crosses also helps prevent your back tire from kicking the debris into the air behind you.
Thats for going over large obstacles at slow speed. Same principal that on your bicycle, you get to a tall curb, you actually step on the pedals and pull up on the handlebars to pull the front wheel up to it. It's more effective on bikes a wee bit smaller than Harley's too. Heck, you could wheelie a sport bike over a two inch bump in the pavement.
When you're going 50 on a Harley and there is a two inch bump in the road directly ahead and all the way across, you want to slow as much as you can and then let off the throttle You're not gonna get the motor to push the weight back all that much on a Harley and if you do mash the throttle hard enough to take significant weight off the front, all you're gonna do is make the bike hit at a way faster speed and be way less stable.
Ya and don't forget to "clutch it" just a tad when you rev it up so the front end lifts in the air over the obstacle........then let off quick so the back end doesn't slam the front end down and bend the front wheel.......you don't wanna bend the front wheel do you??
Same thing I was taught. The blip unloads the weight from the front end. Get as close to 90 degrees as possible. And as Silverback said roll off as you hit...
