ORIGINAL: anubisss
How did the connectors come with the guage? Did they come without the connectors on and they you run the wires and connect them, or did you have to take apart the connector on the skull fuel guage just to run it throgh the hole for the wires? I have the gas cap...see, just want to know about the wiring connectors before purchasing the gas guage. I use the odometer for gas puposes anyway. I don't trust that gas guage leveler worth a dime.
The skull guage wires directly in, just gotta pull the tank. But since you already are just put it together when it all goes back on.
It comes with the wires loose and after you run the wires through the tank it supplies you with a new connector. The only thing that you have to do is take the long gray wire take the center console off take the plug connector off the speedomter cut the yellow wire and connect the gray wire fron the new gas gauge to the cut yellow wire. That is the wire that makes the low gas symbol flash when you are about to run out of gas. Have any questions email me I'll be more than happy to help.
Do you have to remove the tank to get the wire through.
