Remember this bike ?
Old Jan 5, 2011 | 04:10 PM
  #31
Bandit29's Avatar
Bandit29
Would love to see it really clean and rode like it is.
Old Jan 5, 2011 | 04:20 PM
  #32
silverwolf79's Avatar
silverwolf79
Nice find , curious to see what you do with it .
Old Jan 5, 2011 | 04:30 PM
  #33
schumacher's Avatar
schumacher
very nice find
Old Jan 5, 2011 | 04:44 PM
  #34
Turbo Flux's Avatar
Turbo Flux
You can't buy a total wreck Harley around here for $1500. I would have jumped on it too.
Old Jan 5, 2011 | 05:10 PM
  #35
Bike-R-Mike's Avatar
Bike-R-Mike
Well , there was a big oil spot under the bike and in the first thread everyone was saying it had to be torn down . But I noticed that the petcock on the tank had been left on and I KNOW from experience on the older bikes "because I did this to myself on an old Sportster once" that if you leave the gas on it can slowly drain down into the base of the motor . the thinned oil will then wick through gaskets . So I intend to change all the fluids on the bike , spray oil in the cylinders and crank it a few times with the kickstart and then give a try at sparking it up . If it runs I will let it run for a bit and then do a second oil change on the motor (because of the gas that I'm sure got in the bottom end) and it should be good to go . Well after other things are adjusted and oiled and lubed . The tires even look great on it and hold air , but they are cracked with age and will be changed . Saddly I won't be doing all this for a while as I have no garage to work in and it's winter here
Old Jan 5, 2011 | 05:11 PM
  #36
BobStreetBob's Avatar
BobStreetBob
Good find, good deal,good project. It's all good.
Old Jan 5, 2011 | 08:17 PM
  #37
MCSarge's Avatar
MCSarge
Excellent find and great price not matter where your from. I got my 87 FXR for 2000 and thought I stole it. I would be beside myself if I could find a 65 for 1500 no matter what motor it had. Good luck on your project.
Old Jan 5, 2011 | 09:59 PM
  #38
j1mmy's Avatar
j1mmy
you did good,the cheapest shovel,or any twin, i have ever seen is $2700,and it was a basket in a hundred rusty pieces..some of the people on here are nuts(the 60's deals are LONG gone)..have seen that frame alone sell for 1500 if it was clean and origenal..if you need a garage, i have plenty of space here in ne ohio..
Old Jan 5, 2011 | 10:30 PM
  #39
WS6 Formula's Avatar
WS6 Formula
That cleaned up quite a bit, just needs some detailing and it will be a nice rider as it is.
Old Jan 5, 2011 | 11:01 PM
  #40
BassCatcher's Avatar
BassCatcher
Great find and it looks like a great project. Be nice to keep her the way she is and ride the heck out of it.
