a few weeks ago while changing oil in garage i had set my keys with fab next to tool box.. after oil change took for a short ride and forgot keys.. duh.. well the bike will run fine but i stopped for gas...that is when i realized i forgot keys as it wouldnt start.. had to call the wife,
there is a procedure that you can do that would negate the need to call the wife, have her bring the keys, and then rag on you for weeks afterwards.... its in the owner's manual. learn it, live it.
what would you have done if you were 3 states away and lost your fob?
Not to mention the fact that if you're one of the owners that didn't read that part of the manual, chances are the thief only has to be smart enough to count to 1.
If you haven't reset your security code, you're Key fob is kinda redundant.
Change it out once a year when you renew your registration for peace of mind so you aren't left with a bike that won't start an no battery in sight.
if it helps you sleep at night, go for it. myself, i don't like to buy batteries when i don't need to, so i use the one that i have until it doesn't work anymore.
i know my code, i know the procedure to use it. when the fob doesn't work, i use my code. then i either stop by walmart, or dollar general and pick up a new one. it isn't that inconvenient, and my last battery lasted 3-1/2 years.
