Motor question
Old Jan 20, 2011 | 05:28 PM
PaulD's Avatar
PaulD
Default Motor question
Purchased a used 06 softail.
Its an 88 inch motor with 95 inch kit and it is supposed to have SE cams.
If I pull the cam cover plate will I be able to see the end of either cam and if so, should there be a number stamped to identify if they are actually SE cams and which ones?
If not, what has to be done to id the cams?
Thanks.
Old Jan 20, 2011 | 05:32 PM
Mike T's Avatar
Mike T
Contact the owner who "supposedly"put it in there to verify it.
Old Jan 20, 2011 | 06:01 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Ask who did the work, a dealer should have it on file, by VIN. If an indy did the work the seller should have a reciept or the the indy may have some files on it.
Old Jan 20, 2011 | 06:25 PM
Stiggy's Avatar
Stiggy
I think you'll see maybe SEH 203 or perhaps SEH 255 on the end of the cams if they're Screamin' Eagles.
Old Jan 20, 2011 | 06:35 PM
PaulD's Avatar
PaulD
I went to the dealer. Its not in the computer, as far as cams, but the mechanic was there who did the work and says they definitely did change the cams but he is not 100% sure which ones went in.
Thats why I was asking if its simply a matter of me taking that cover off and being able to see something or if any numbers would be hidden by gears.
Someone who knows the internals of these motors would have to answer that.
Old Jan 20, 2011 | 07:28 PM
wideglidebob's Avatar
wideglidebob
well for heavans sake take the friggin cover off and see
Old Jan 20, 2011 | 07:47 PM
Rickey's Avatar
Rickey
Hahaha!!! Right!
Old Jan 20, 2011 | 08:09 PM
CroK's Avatar
CroK
No...
Taking the cam cover off will not give you a clue. Now, if you also remove the cam support plate and then the cams from the cam plate, you should find a stamped number on the side of the cam lobe indentifying the cam(s).
(Mine have SE204 on them, because that's what they are.)
Old Jan 20, 2011 | 09:32 PM
PaulD's Avatar
PaulD
Thank you CroK. Thats why I did not want to just "take the friggin cover off".
Appreciate the help.
Might be more to it than I am able to do regarding the cam plate and the actual cams.
BKBIGGZ
Engine Mechanical Topics
Aug 25, 2015 04:57 PM
WarriorHD
Oct 28, 2010 02:52 AM
bigbean78
Screamin Eagle CVO Models
Jul 25, 2009 11:11 AM
bigbean78
Jul 18, 2009 05:13 AM
d.dimperio
Exhaust System Topics
23
Mar 17, 2008 01:29 AM
