Mechanical speedometer help needed
Old Jan 25, 2011 | 08:38 PM
FlamedFXR's Avatar
FlamedFXR
Default Mechanical speedometer help needed
Ive got a 1936-40 style face speedo on the fxr that I have to replace because the trip reset **** broke off inside. No reed switches, strictly mechanical.
What would be the best way to bring the mileage up to match the old one? 31,000 miles.
I was thinking about hooking an old cable up to a drill and just letting it spin around until it got there. Any experience with this?
Old Jan 25, 2011 | 09:10 PM
JohnnyC's Avatar
JohnnyC
Default Maybe you won't have to replace the whole unit.
Have you gotten a good look at what's left of the trip reset **** shaft inside the housing?
Sounds like someone attempted to lift the speedo out of it's housing with out taking the trip **** off first.
I'm going to guess there's still a piece of the (broken) plastic trip **** shaft attached to the metal shaft inside the casing. They bolt together with a #1 Phillips head screw and require a tiny #1 phillips screwdriver with a long thin shaft to reach deep inside to remove / replace that screw.
I hope it turns out to be that easy.
Old Jan 25, 2011 | 10:17 PM
FlamedFXR's Avatar
FlamedFXR
No its deeper than the **** threads.... the shaft broke inside and some tiny parts fell out.
Old Jan 25, 2011 | 11:35 PM
wlbowers's Avatar
wlbowers
Several people that rebuild the old units.
speedometershop.com/
North Hollywood
Speedometer Repair Service
TXWarthog
EVO
14
Nov 13, 2017 09:56 PM
Rusty Axle
Shovelhead
Jun 21, 2017 09:34 PM
Noxx
General Topics/Tech Tips
Jun 9, 2013 02:07 AM
adachris
Shovelhead
Nov 17, 2012 06:36 PM
tas_todd
EVO
Feb 6, 2011 04:47 PM
