Tune or Not to Tune - That is the Question
Old Feb 13, 2011 | 03:22 PM
shore's Avatar
shore
I'd run the XIED's and call it a day. That will richen you up for $100 and the engine will run cooler.
No need to drop $700 to accomplish this unless you're doing bigger mods.
Old Feb 13, 2011 | 07:25 PM
oct1949's Avatar
oct1949
Pipes, A/c and tuner of some kind is done by probably 75% or more of us...
she'll run, start, better, cooler, and give a little more TQ and HP..
put in a cam and U'll be amazed at how much more/better she'll run.
Old Feb 13, 2011 | 07:33 PM
blusmbl's Avatar
blusmbl
Originally Posted by Stiggy
No he's not...Stock bikes are running very lean, 15 or 16 to 1 Air/Fuel ratio
No they aren't. A/F ratios that lean will melt catalysts, and not pass emissions.
Old Feb 13, 2011 | 08:14 PM
hdgzr's Avatar
hdgzr
Here's some interesting information:
"The OEM Harley-Davidson closed loop fuel mixture is 14.6:1. On Twin Cam 96 engines, the closed loop range generally covers under 4000 RPMs and under 40% throttle. This is going to be 95+% of the time an average rider spends on his bike. Even the most aggressive rider would find it hard to spend more than 5% of this time in open loop.
For those of you concerned about open loop fuel mixtures, on TC engines these are set from 13.8 to 12.5:1 depending upon RPM and engine load. So these mixtures are quite adequate for performance work. Riders that are worried that exhaust and air cleaners are going to lean these mixutres out need not worry. Changes in exhaust/air cleaners are only going to change these AFR's by .3-.4 point, yielding 14.2 to 12.9 AFR in a worst case situation. These are still not fuel mixtures that are going to hurt an engine under wide open throttle situations."
I would tend to agree that dyno runs on a stock bike are a waste of time and money, although it would provide a baseline to judge future mods.
Old Feb 14, 2011 | 04:04 AM
Stiggy's Avatar
Stiggy
That's good info, Thanks. The ' 08 SE Ultra ( no cat) at our
shop did run 16 to 1 out of the box, but we suspected something was wrong which is why we checked it. We hoped it was a fluke, and not a common thing.
chugger93
Mar 6, 2014 08:46 AM
fella
Jan 10, 2012 11:45 AM
IronAK
Jun 22, 2011 10:36 AM
jtwendel
Jun 9, 2011 05:30 PM
HOTROD1300
Mar 21, 2008 10:43 PM
