cruise control
Old Feb 24, 2011 | 08:07 AM
rydahog's Avatar
rydahog
Default cruise control
Any one know if a 97 cruise control from an ultra will fit a 06 heritage..thanks.ryd
Old Feb 24, 2011 | 08:21 AM
Zac Strayer's Avatar
Zac Strayer
I was just wondering about this. i saw where you cold buy a add-on to put on your throttle to allow for cruise control.
My question is does it work like a car to where when you step on the brake it releases or would you have to actually manual turn it back off?
sorry but i dont know the answer to your question but was wondering about cruise control myself.
Old Feb 24, 2011 | 08:27 AM
rydahog's Avatar
rydahog
zach,, the cruise on my ride is very similar to car cruise..resume/accel/and with the new hd when you hit the rear brake it goes off, and also front brake. to get back up to speed ,like after a toll booth, just push it forward and off you go to set speed..later ryd
Old Feb 24, 2011 | 08:31 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Cruise control systems changed radically between the days of carbs and actual throttle cables and modern EFI and throttle by wire.
Old Feb 24, 2011 | 08:34 AM
nhbiker1961's Avatar
nhbiker1961
Yes, this is true because with throttle by wire, you can roll the throttle back beyond the idle position to disengage the cruise control.
Old Feb 27, 2011 | 10:48 AM
sarge205's Avatar
sarge205
yo, ryadahog, i was wondering if it might fit on my 06 SG. guess about the only way to know for sure would be to do some research on the part # if you can provide it i will certaily do some calling.
Larry Nawara
Sep 14, 2013 05:05 AM
Jukebox
Jul 17, 2010 01:04 AM
JCleary
Oct 9, 2009 05:37 AM
1953riderforlife
Aug 18, 2009 04:39 PM
Woodchuck
Apr 27, 2007 07:26 PM
