stripped header bolt (phillips head), need help please!
Old Mar 13, 2011 | 07:49 AM
  #111
FroggyFatBoy's Avatar
FroggyFatBoy
did he get married yet ?
Old Mar 13, 2011 | 08:05 AM
  #112
dog155's Avatar
dog155
Steel bolt in aluminum and for so many years Yikes you have a conundrum.Other than taking head off and letting a machine shop take the bolt out,you have few options.One is cut bolt off flush with head center punch drill it out, then Helicoil it.Good Luck
Old Mar 13, 2011 | 08:22 AM
  #113
1flhtk4me's Avatar
1flhtk4me
I guess Honda realized somewhere down the road that using flat head screws on the 4's was not a a good idea,my sons '82 CB750 has hex bolts
Old Mar 27, 2011 | 05:39 PM
  #114
Trucky911's Avatar
Trucky911
Dean did you get it out yet?
Just wondering....
Trucky911
Old Mar 27, 2011 | 06:12 PM
  #115
lo-rider's Avatar
lo-rider
Inquiring minds want to know what worked for you. You even inspired me to start a thread on avoiding stripping/breaking fasteners. You just don't know how I've learned the hard way.
Anyway, are you just playing w/ your welder, or are you too embarrassed to admit that you finally hired a pro?
Old Mar 27, 2011 | 11:47 PM
  #116
V2Evo96's Avatar
V2Evo96
As the OP (Orisisdean) was in the process of wedding plans methinks the screw removal has taken a back seat....
"Hold that thought about the wedding photographs and your dress dear, I've just got to get this stuck screw out-- be with you in an hour or so."
Strange how women have their priorities all wrong....!
Old Mar 28, 2011 | 12:29 AM
  #117
Other Sheep's Avatar
Other Sheep
Honda?
Old Apr 24, 2011 | 03:18 AM
  #118
FroggyFatBoy
well ??? the honeymoon has to be over by now...
Old Apr 24, 2011 | 09:02 AM
  #119
Budmiester's Avatar
Budmiester
The only reason to get married is because your tired of having sex.
Old Apr 25, 2011 | 07:44 AM
  #120
osirisdean's Avatar
osirisdean
lol, sorry gang.
so i was all set to try the welded-washer-and-nut-on-top trick aaand... noticed that the heat dissipation fins on the engine around the bolt holes make it IMPOSSIBLE to put a washer on it. so i wouldve had to weld a nut directly onto the seized bolt, which i didnt feel comfortable doing. (the last thing i wanna do is weld the bolt/nut to the engine case.)
i pussed out and brought it to the dealer, who initially said they would charge me $180 for it, but since i got some other stuff done, i think it ended up being less than that. (got the bolt removed, gas tank sealed, leaky gasket replaced, and carbs cleaned and rejetted to match a new 4-into-1 exhaust and pod filters... all for $650 i think.)
definitely appreciate all the suggestions everyone made, loads of good advice.
