stripped header bolt (phillips head), need help please!
Old Mar 1, 2011 | 06:14 PM
  #91
FroggyFatBoy's Avatar
FroggyFatBoy
Originally Posted by Faast Ed
Dam you,.... I have to clean the spray off my monitor again. You seem to make a habbit of that ****. Bwahaha!
Can I use that in my Siggy? That's a pretty cool lie. LOL (I meant line).
go for it..
Old Mar 1, 2011 | 06:44 PM
  #92
Faast Ed's Avatar
Faast Ed
Originally Posted by never say never
you can slowly work it out with an engraving too,by catchin the edge of the bolt or nut with the pont of the tool the hammering action along with the vibration will start to loosen it up.
The upside to that is if you ever lose the bolt, they will know who to return it to.
Old Mar 1, 2011 | 07:52 PM
  #93
1flhtk4me's Avatar
1flhtk4me
Originally Posted by V2Evo96
The OP is running a MIG so arc strike degree of difficulty reduced a bit.....
Your right.
Old Mar 2, 2011 | 06:53 AM
  #94
osirisdean's Avatar
osirisdean
Originally Posted by midnight2005
There comes a time when you gotta ask yourself, just much is it worth?
How much you got in this bolt right now counting mig welder and all? There is a time when it is cheaper to just drill off the head and take it to the machine shop, or drill and tap it yourself.
When you weld that nut to it,if it does not work, the nut is now another obstical.
the MIG was a necessary purchase for a future project (on the same bike), so there's not really any added cost there.
youre right though, if welding a nut onto it doesnt work, i will have made the rabbit hole deeper. im hoping that with practice (i even have an extra dead engine to practice on if necessary) and patience, i can do it.
and faast ed is right on -- part of this is the challenge of it. when i bought this bike, i wanted and expected a massive project. this is a very frustrating step that may not seem worth the trouble, but i want to do as much of it as possible myself, if for no other reason than to be able to say i did.
regarding cutting the flange: id rather not do that unless i have to, but i havent ruled it out yet.
btw, no update as of yet, work has kept me busy. might be able to fiddle with it tomorrow some. will let you guys know what happens.
Old Mar 2, 2011 | 03:57 PM
  #95
V2Evo96's Avatar
V2Evo96
TO OSIRISDEAN:
If welding the nut doesn't work for you the worst case is it will come off in your hand as soon as you try to turn out the screw.
If that happens take your dremel and grind any dags/burrs off the screw, get a fresh nut and try again...
You can do this-- and you will be surprised how easy it will be to back the stuck screw out. All you need is a good solid 'tack' on two sides of the inside of the nut, but it doesn't matter if your control is poor and you fill more of the nut with weld than you wanted to-- as long as the weld is solid it will back out.
Run some weld beads on a piece of flat steel to help steady your arms and get the heat setting right before getting a handful of nust to practice with. You will know when the heat is right--it sounds like bacon sizzling in a pan and the arc will strike easily. Try to brace your arms and cup the control head like you would shoot a pistol two handed-- steady is key in putting down a good bead.
If the arc is hard to start the setting is too cold so go up 5 amps and try again; repeating as necessary till it's right. I'm guessing about 80 amps (+-), will put you in the ballpark to start then re-set from there.
When practising remember to keep your eye on the weld puddle and don't leave the puddle i.e. 'pull ahead' of it, or stay in it too long. Keep the wire in the puddle and move forward slowly. You won't need to weave the bead for this job-- just run the wire straight ahead.
When you weld inside the nut it probably won't be pretty but that doesn't matter. The nut will take the heat before the screw so you may need to 'favor' the puddle onto the screw side a little bit. You will only be inside the nut for a couple of seconds on each side but you must place the puddle so it melts into both the screw and the nut.
Sorry to be so wordy with the above but I wanted to try to paint a mental picture for you while you practise. You can do it!
Old Mar 2, 2011 | 04:30 PM
  #96
Faast Ed's Avatar
Faast Ed
TO OSIRISDEAN:
Nice post.
Old Mar 2, 2011 | 05:53 PM
  #97
Steelhammer's Avatar
Steelhammer
Nice post.
Yessir, and remember to put your ground close to your work and not on your frame.
Old Mar 2, 2011 | 07:06 PM
  #98
V2Evo96's Avatar
V2Evo96
The at work IT system won't let me quote Steelhammer but as he said place the ground as close to the work as possible and not on the frame.
Also make sure the battery is disconnected before striking your arc as bad things happen when electricity meets electronics (if any) on your project bike.
I can't see any pictures either from work other than avatars and sig pics.
Old Mar 2, 2011 | 07:41 PM
  #99
creatv1's Avatar
creatv1
Nice post.
wow I think V2EVO96 just taught me how to weld! I'm printing that thing out!
Old Mar 7, 2011 | 06:47 AM
  #100
osirisdean's Avatar
osirisdean
TO OSIRISDEAN:
very much appreciated, thanks for the tips!
today im going to call a local steel shop and see if i can dig through their trash bin for some metal to practice on and hopefully make some sparks fly tonight.
