stripped header bolt (phillips head), need help please!
Old Mar 1, 2011 | 04:49 PM
  #81
midnight2005's Avatar
midnight2005
There comes a time when you gotta ask yourself, just much is it worth?
How much you got in this bolt right now counting mig welder and all? There is a time when it is cheaper to just drill off the head and take it to the machine shop, or drill and tap it yourself.
When you weld that nut to it,if it does not work, the nut is now another obstical.
Old Mar 1, 2011 | 04:50 PM
  #82
Faast Ed's Avatar
Faast Ed
Originally Posted by FroggyFatBoy
or your OL's poonanny is sore...
Better hers than mine,...... he he!
Old Mar 1, 2011 | 04:54 PM
  #83
FroggyFatBoy's Avatar
FroggyFatBoy
thats cause you aint doin it right...
Old Mar 1, 2011 | 05:01 PM
  #84
Faast Ed's Avatar
Faast Ed
There is a point where it becomes about the challenge, not about the dollars (he wants a welder anyway).
The ol' "I can do this" thing.
I used to tear apart mill motors, huge electric motors from the steel mills.
6 - 7 thousand pounds was a medium sized motor. They are used in some real corrosive environments and we often ran across bolts that "thought" they were a permanent part of the motor.
Eventually I got to where they could not whip my ***, and it became extremely rare that I had to cut the heads off of any of them.
The "challenge" became kind of a game to me.
Where I saw a lot of bolts that resembled the OP's bolts, were on the traction motors, the ones that they use on Metra and other mass transit people movers. They were always froze, and the red hot trick turned them into childs play. Not even a challenge after that (yet impossible to budge prior to heat).
Also, don't forget, there is a lot of extra work involved pulling the heads. Unless he plans to beef up his motor, it would benefit him to avoid having to do that extra wrenching.
Old Mar 1, 2011 | 05:04 PM
  #85
Faast Ed's Avatar
Faast Ed
At least you didn't make any accusations where size was an issue. LOL
Old Mar 1, 2011 | 05:09 PM
  #86
TwiZted Biker's Avatar
TwiZted Biker
Even if the guy is hung like a gerbil she'll think it was beer can if he can swivel the hips like Elvis .
Old Mar 1, 2011 | 05:15 PM
  #87
FroggyFatBoy
I've never had to defend "the package" ...
Old Mar 1, 2011 | 05:33 PM
  #88
ConnMan's Avatar
ConnMan
Cut the flange. Pull the pipe out. You'll have all the room you need...
Old Mar 1, 2011 | 05:35 PM
  #89
Faast Ed's Avatar
Faast Ed
Dam you,.... I have to clean the spray off my monitor again. You seem to make a habbit of that ****. Bwahaha!
Can I use that in my Siggy? That's a pretty cool lie. LOL (I meant line).
Old Mar 1, 2011 | 05:51 PM
  #90
never say never's Avatar
never say never
you can slowly work it out with an engraving too,by catchin the edge of the bolt or nut with the pont of the tool the hammering action along with the vibration will start to loosen it up.
