stripped header bolt (phillips head), need help please!
Just gotta be careful not to melt it. Keep that torch tip moving.
I can visualize him carrying the head into the shop, with the pipe still attached. He he! Kodak moment!
Correct, see post 33. It's a countersunk head & there won't be anything left to grip. An oval head might be tough to snug tight
i think for any other bolt, any of the offered methods shouldve worked, but this one was just destined to be my nemesis.(if anyone does want to talk me out of welding a new head, you'll have at least a couple days since i have to snag a MIG & safety equipment and practice a bit.)
I had to use a stick welder with a 3/32" GP rod as I didn't have a MIG handy, but I'm an experienced confident welder.
The heat input worked a treat and while it was hot I hardly had to turn the nut and the stud nearly fell out.
Also you might want to consider draping some very wet rags over anything nearby that you don't want to burn, discolor or risk weld spatter sticking to someplace where you don't want it.
I would suggest that if you have a friend who is handy at welding I'd be asking him over and shout him a couple of cold ones for helping.
YOU can do it though-- just practice a bit and get your heat right. Get into a comfortable position (if possible) and steady your arms against the frame, header, or whatever is handy-- it will improve your chances for a good bead inside the nut.
Good luck and let us know how it goes.
(i needed that laugh, too. much appreciated.
side note: before doing the weld, i still plan on exhausting my other options. going to attempt another screw extraction, this time with heat. (i suspect that faast ed was right, and i wish i had tried heat from the getgo before stripping the bolt head. doh!)
Starting an arc with a stick welder can be tricky for a novice.
