i use a pointed center punch and tap gently on the outside edge putting a small dimple in the screw head and gives me a starting point. now i reposition the punch on a angle to drive the screw CCW and give it a couple of good smacks with a hammer.
Yep,this method may work also if theres enough room to swing the hammer.
Before you go and really bugger things up by drilling, get some valve grind compund. Assuming you've already soaked the screw with penetrant oil, use the compund to give bite to the screw driver, just dip the tip in it, also make sure your using the right size tip. If your screw driver has a square shaft, use a wrench as a handle to increase leverage/torque. A set of vice grips will serve the same purpose. Lean in to the screw driver with as much *** as you can put into it, and work the handle back and forth to break it free. This will work alot of the time, but I hate it when it gets to the point your drilling stuff out. Good luck. If that doen't work and you do have to start drilling, make sure you use a spray lube to get any of the compound out of the head. Valve grind compound will turn a new drill bit into worthless smoke generator in about 1 second.
Now that I looked at the pics again,I think Golf may be right about nothing to grab on to.
The only problem is if the screw does not unscrew,the Sears tool will just cut the head off.
The Sears tool will work but put the drill in low & proceed slowly.
Here's another unique way if your a golfer. Drill 2 small holes in the screw head (center punch first) if it's wide enough the same distance apart as a golf shoe spike & insert the spike remover in the holes. The hole only need to be 1/16-1/8"
deep. It's good if you have the ratchet type tool with a handle. Unscrew, it should work.
Heat is your friend. Get that bolt real hot and try again.
If the Phillips head is way stripped, try a dremmel to cut a slot in the head.
Another trick that never fails me as a last resort, a nice sharp 1/4" chisel, tapping the head counter clockwise. Sometimes you have to dress the chisel again to keep it sharp. Just keep aiming it so it's impact is driving the bolt counter clockwise.
Matter of fact this method works without the heat. (But heat is your friend).
Kroil is NOT a permanent lubricant. try it and find out...
Fascinating stuff but...
He said PENETRANT....not Permanent.
I know he said penetrant.
He also said lubricant. I only pointed out that it's not a permanent lube...as in don't use it on cables or other places where you need to lubricate something.
However, if YOU want to use it, go ahead.
just looked at the picture...start by using a hardened bolt as a punch,big enough that it doesn't damage the screw head,give it a few good wacks.then use a good impact driver,the kind you turn while beating the crap out of it with a hammer.make sure the bit you use fits the screw head good.if that doesnt work,grind a flat grove in the screw to make a flat head screw.use a flat head bit with the impact driver.that should take it rite out.if that doesnt work,you are going to have to get a sharp centerpunch,tap the edge of the screw around a circle.if you dont have the tools or ability to get it out take it to a bike,or machine shop before you damage the screw anymore.it isnt a big job so it should be pretty cheap..dont drill on the screw any,that will only make it harder to get out.most likley you will ether end up with a drilled out/broken stud in the cylinder head that a machine shop will have to get out.or a ruined head all togeather
#1 removal of other screws might be placing some load on last bolt.
Consider replacement of a couple of screws (lubricate so they do not get stuck)
#2 lube screw with everything you have available
#3 See if some kind of bit will work for you, flat, torx, allen etc. the grinding paste mentioned would increase some grab...impact hammer style if possible
#4 if things fail then try to cut a long slot and return again at number #2...but would appear you have limited room for cutting with dremel unless you have the flexable extention.
Could someone wiggle the header pipe while you work on screw? might just be bound-up.
