stripped header bolt (phillips head), need help please!
so...
out come the big guns: gasless MIG welder.
the plan is to weld a nut onto the head of the bolt and just torque it out normally with a wrench on the "new" head. the heat should also help break up any rust and loctite, im hoping.
the downside: i have zip and pip experience with a welder, so im reading/watching videos/talking to folks about how to go about doing this. it *seems* simple enough for anyone with welding experience, so im hoping if i do a few practice runs, it should be possible.
(if anyone thinks welding a new head onto it is a bad idea, definitely let me know!)
i think for any other bolt, any of the offered methods shouldve worked, but this one was just destined to be my nemesis.(if anyone does want to talk me out of welding a new head, you'll have at least a couple days since i have to snag a MIG & safety equipment and practice a bit.)
http://www.sears.com/shc/s/p_10153_12605_00952151000P
I think welding a bolt on it would make matters worse, especially if that bolt happens to snap.
Try the heat method combined with the above tool. Trick is a the instructions say, "GO SLOW".
Good luck, let us know the outcome.
Did you try one of those impact wrenches that you hit with a hammer? It takes bits just like a drill/driver. If you could get a drill/driver bit that was about 6" long in a #2 Phillips head (sears has them) then wail on it with a hammer it might work. The extra length will give you working room to swing the hamnmer.
I'd shy away from the welder and try to think of a way you can get some super heat on it. Make the bolt almost red. Let it cool and go back to your earlier methods with tap & hit.
I sure wish you lived near me, because I would enjoy the "challenge". I've had some really bad ones that I always was eventually able to get. I consider myself good at it.
Your pics show some real challenging angles, but if they were stupid enough to put a phillips head on there, there must be "some" access to them. LOL
Gonna be watching this one closely for the victory dance.
go ahead and practice on some other nuts and simliar bolt heads until you feel confident that you can do it..
even if you don't weld a nut on, you could put a weld nub on the screw head to give you something to grap a hold of with pliers or vice grips and turn it loose..
On the welding, just sayin you might want to find someone with experience to tack the nut for you or you could end up with a mess, Burning through the sides of the tapered head of that bolt and accidentally welding to the header flange. Heat will definately be your friend, and don't burn your friends fingers or you will owe him a beer............lol.
