Battery Lifespan?
Old Mar 2, 2011 | 07:56 PM
Bricklayer's Avatar
Bricklayer
Default Battery Lifespan?
How long does a battery generaly last. I'm from Michigan, so battery is on a tender for 3+ months thru winter. 09 Dyna low rider, would appreciate any input. Thanks
Old Mar 2, 2011 | 08:09 PM
lohawg's Avatar
lohawg
I got about 8 years on my 97 low rider battery, only time I didn't put it on the tender was in spring/summer when I knew I would ride again within a week. It didn't die on me either, I changed it pre-emptively before a trip after it showed a little sluggishness on start."tenderize" is my motto, it never hurts to keep it plugged in.
Old Mar 2, 2011 | 08:13 PM
jimmers1817's Avatar
jimmers1817
Depends. I've seen car batteries go as long as 9 years w/o a problem and then quit w/o warning. Then again I've seen others go in 3 years. Probably the same deal with bike batteries. My Heritage is going on 4 years and seems fine. I use a tender during the winter also.
Old Mar 2, 2011 | 08:14 PM
warrconn's Avatar
warrconn
3 or 4 thousand threads on this, I'd guess.
Old Mar 2, 2011 | 08:15 PM
FBRR's Avatar
FBRR
I use to take my battery out every year. They lasted about 3 or 4 years.
After I started using a tender I've changed at 5 years and the battery was still fine, just 5 years old! I think using a tender is better than removing the battery.
Old Mar 2, 2011 | 08:56 PM
Hogaholic's Avatar
Hogaholic
I changed mine after 4 years before heading to sturgis, still was starting ok. I use a tender 1 day a week in the winter.
Old Mar 2, 2011 | 09:00 PM
dh2683's Avatar
dh2683
5-7 yrs on AVG. with a battery tender on a orig. HD battery.
Again I said ON AVG. cause someone will chime in how they got 11 years out of one.
Old Mar 2, 2011 | 09:27 PM
Bluehighways's Avatar
Bluehighways
Four things affect battery life:
1.) Heat - Higher Temperatures = Shorter Life (Desert Southwest = 24 to 26 months) Note: Low temps are OK as long as the battery doesn't freeze (fully charged freeze point is ~ -90F, Discharged Freeze Point ~ +32F)
2.) Cycling - More and deeper Charge and Discharge Cycles = Shorter Life
3.) Deep Cycle (under 50% State of Charge) = Much Shorter Life, About 5 Deep cycles can pretty much do in a Lead Acid Battery.
4.) Vibration - Unsecured Battery and/or Bungee Cord/Coat Hanger etc = 1/2 Normal Life
Item # 2 is why folks who use Battery Tenders religiously tend to experience longer battery life that those who do not.
Old Mar 2, 2011 | 09:31 PM
jamminjim's Avatar
jamminjim
Got a 06 Ultra with the original battery. Got it in Feb. of 06. Don't put it on a tender very often.
Old Mar 2, 2011 | 09:32 PM
oct1949's Avatar
oct1949
Getting the Idea... U need a tender on any battery that sits for a while..
mine,,,,, 4yrs and still goiiiiiiiing... and yeah she's on the tender all winter...
