I like to use lacquer thinner for just about everything. I've used it on harley chrome, aluminum and even paint, with no problems. Not much else disolves hardened oil and grease like that.
So the pink stuff is that like a degreaser? I bought a bunch of stuff the other day I may have to look for that one too. How would I seal up the openings? I think I heard someone say that I can buy covers for the lifter blocks and for the jugs too but I bet some old rags or t-shirts would do the trick. Sounds like a good idea before putting the buffing wheel on it
If you can put freezer bags over the openings and an elastic band. Do not point the nozzle directly at the openings. Pink stuff is a good general cleaner, non abrasive, wont hurt pain and works really good. I use on my truck wheels to get rid of the brake dust and general cleaning. Of course if you have access to a pressure washer you can do the same thing. Car washes usually use warm water, couple that with soap and you will get a good clean.
Not comfortable using lacquer thinner on clear coat paint. I will take your word it works.
Buckinfitch I gotta say that is one of the most awesome sights I've ever seen man! Don't know if I could get away with that in the living room though HAHA! You know I've heard of soda blasting before but from what I could tell it seemed like it was too expensive. Hatchetman if you have a link to a homebuilt remedy that might work out real well, I was going to use it for my old 72 short-wide but it never dawned on me to use it on this engine
