oil oooz
Old Mar 8, 2011 | 08:59 AM
Mal74's Avatar
Mal74
Anytime you take the oil cap off be sure to wipe the seal and the inside of the filler area with a paper towel. It seals better if there's no oil on those places when you put it back in.
Old Mar 8, 2011 | 02:37 PM
oldairboater's Avatar
oldairboater
You changed the oil over a seep down the oil tank and used a different oil. That makes no sense to me. What are you going to do if this dino oil seeps down the oil tank? Change transmission fluid?
Old Mar 8, 2011 | 03:31 PM
cdestuck's Avatar
cdestuck
Whats with the 24 hour drain time. Gee, you probably only got that engine half drained out. Do mine at leat 48 hours. Primary gets a 72 hours drain time.
Old Mar 8, 2011 | 04:03 PM
big cahuna's Avatar
big cahuna
I usually wait a week to ten days for a through drain. I've heard if you use amsoil, it will repair any leaks by itself, check its own level, put air in the tires and keep your bike cleaned and waxed. Says so in their white paper.,,
Old Mar 8, 2011 | 05:20 PM
MisterPX's Avatar
MisterPX
Magic question is how much oil came out, versus how much was supposed to be in there.
Old Mar 8, 2011 | 06:50 PM
paud's Avatar
paud
In the famous words of Ahkmed the Terrorist via Jeff Dunam...:HOLY CRAP! hahahah
About 3 qts. came out
Iron lHorse
May 16, 2017 07:53 PM
geter712
Jun 24, 2013 05:10 AM
sam 1965
Apr 6, 2008 04:02 PM
Kski
Oil Archive (no new posts)
Mar 19, 2008 12:04 PM
wrinspect
Shovelhead
Jan 4, 2008 08:35 AM
