I bought my 2005 Road King last summer and had the tires replace last weekend. I took the wheels off and took everything into a local Cycle Gear to have the tires put on. They guy who put the tires on said that the rear took a lot of weight (told me how much, but I can't remember right now). I did not think about it at the time, but for some reason it just hit me this morning that maybe there is a problem with spokes being loose? I have not had a chance to ride the bike yet. Been crappy weather here since I got them put back on.
So first question is - Is it possible that some of the spokes are loose and that is why the wheel needed so much weight?
Can I check the spokes with the wheels on the bike? How can I check them?
What brand of tire and how much weight? In the meantime, did he put the weights on the spokes where they are supposed to be or did he mount them on the rim. Is the dot on the tire aligned with the valve stem? Did he take the time to look inside the tire and make sure he took out all the shipping cardboard? If the weights are over about seven ounces, I would have them remount the tire.
Thanks handyhoward for the response. The weights are on the rim and not on the spokes. There are other weights on the spokes from the previous mounting. I will check out how much weight when I get home tonight. The tires are D402's. I will also check to see if the dot on the tire is where it is supposed to be. I did not know to look for that. Thanks!
Answer to Question #1, Sure some spokes could be loose. No that would not cause one to add more weight.
Answer to question #2, Yes you can check them on the bike. Raise bike on jack so wheels will turn freely by hand spinning. Take a phillips driver and rest on spokes with lite pressure and spin the wheel. All spokes should have a ring to them some what similar but not the same. A dull tone will indicate a loose spoke. Repeat on other side and other wheel.
Old weights should have been removed prior to new balance. Some guys are just lazy.
Very cool. Thanks for the info, I will check out the spokes even though they would not be causing the weight issue.
The old weights where not removed so I will have to ask him about it.
If it were me, I would check all spokes, remove all the weights, and pick up the proper amount of Dyna Beads. Been using them for a while and don't think I would ever go back to weights.
They make it easy for me to change my own tires and get a smooth ride.
Phil
Don't know why anyone would balance a tire without removing old weights... unless you were lucky and they ended up in the correct locations.
Are the old weights near the new weights? If not, there is part of the problem - some of the new weights are needed to simply cancel out the old weights.
As far as tightening the spokes go, you should check the wheel for true when adjusting the the spokes. It's also a good idea to have the tire dismounted because depending on how much you tighten the spokes, you may need to grind off the excess inside the wheel, or risk a punture to the tube.
I'm not 100% sure since I do not have the bike here, but I am thinking that the new weights where next to the old weights. Hmm. I will add that to the list to check when I get home.
Sounding more like I will be pulling the wheel off and taking it back in.
