Speedometer Backlight Question
Old Mar 17, 2011 | 05:16 PM
Talldog's Avatar
Talldog
Default Speedometer Backlight Question
This is probably a really dumb question, so be nice.
I switched out the Speedometer on my 11' Heritage to the new Speedo/Tach Combo, part # 74774-11.
http://www.harley-davidson.com/gma/g...7&default=none
I've noticed that when I'm out riding and it's fairly light out, I cannot see the Backlighting for the Speedometer. I've got the color set to Green. It's not that it's just harder to see because of the daylight, it's actually off entirely.
When I pull back into the garage where it's darker, the Backlight comes back on.
Now I know the Dash Lights on cars have a light sensor, and that turns the dash lights off in the daytime, but I didn't think it worked that way on Bikes. I can't remember if the original Speedometer did this or not.
If there is a light sensor somewhere, I can't find it and I've looked in the Owners Manual and the Service Manual, but can't find anything that talks about the Backlighting shutting off in the daytime.
Do all bikes do this, or do I maybe have a problem with my new Speedo? Where is the Light Sensor located?
Thanks
Old Mar 17, 2011 | 05:27 PM
wahlumsurfer's Avatar
wahlumsurfer
Not too sure about a Heritage, but my Sportster has a light sensor right above my ignition. It dims and brightens my speedometer accordingly.
Old Mar 17, 2011 | 06:36 PM
chamokie's Avatar
chamokie
My 07 Heritage does not have a light sensor. Dash lights stay on 24/7
Old Mar 17, 2011 | 08:58 PM
Talldog's Avatar
Talldog
So you can actually see the sensor? If my Heritage has one, it's very well hidden. What year is your Sportster?
Old Mar 17, 2011 | 08:59 PM
Talldog's Avatar
Talldog
Even the Backlight for the Speedo?
Old Mar 17, 2011 | 09:46 PM
wideglidebob's Avatar
wideglidebob
light stays on all the time change bulb for more watts
Old Aug 8, 2011 | 03:56 PM
donutsrd's Avatar
donutsrd
hi,new 11 flstc 1k,thought my eyes were playin tricks on me but my speedo backlight definitely goes out when i pull into the garage,or is iy just coming on??gotte ride at nite to check it out....will let u know
Old Aug 9, 2011 | 06:06 AM
donutsrd's Avatar
donutsrd
ok so i went out at sunset,light is on when started,went about 4 miles got to a light cupped hands around speedo,no back light.everything else working properly.headed down a road i knew had a long over pass.get under the overpass,out of sun,and boom the speedo light illuminates,exit overpass get to light cup hands around speedo light still on,few miles later check again light off.kept ridin,sun went down light came on and stayed on,i guess there is a sensor as it workds properly.nothing mentioned in service manual or owners manual,news to hd tech also.no im not crazy thought i was seeing things the first 1000k,thats why i had to check it out thouroughly.fyi
Old Aug 9, 2011 | 06:32 AM
Talldog's Avatar
Talldog
I thought the same thing at first, but the light is always on, you just can't see it unless it's dark enough outside.
Like I said though, freaked me out at first also.
Old Aug 9, 2011 | 06:46 AM
donutsrd's Avatar
donutsrd
sorry to disagree with u ,like i said first sec or two under the overpass nothin then it lit up,it is what it isi same happens when pulling into garage,thats what got my attention first,thought it was malfunctioning,and some how coming on after touching brakes upon stopping in garage,but...all is fine,btw this is the stock speedo i am referring to.
