Dead Battery?
Old Mar 19, 2011 | 07:52 PM
MikeK02048's Avatar
MikeK02048
Default Dead Battery?
Today was pretty nice so I decided to take the cover off the bike for my first spring ride. I turned the key which started the fuel pump, but when I hit the start switch the engine didn't turn over. Instead all I heard was a clicking sound.
Can I assume that even though I had the battery on a tender all winter that it still did not have enough power to start the engine? Or do I have a more serious problem? BTW-The bike was running fine when I put it away for the winter. And my garage is not heated.
Old Mar 19, 2011 | 08:03 PM
dh2683's Avatar
dh2683
How old is the battery? Kill Switch? Battery Terminals- are they tight.
Old Mar 19, 2011 | 08:07 PM
MikeK02048's Avatar
MikeK02048
Bike is a 2009, so battery is relatively new. I didn't check the tightness of the terminals. Will try that tomorrow.
Thanks.
Old Mar 19, 2011 | 08:24 PM
RollaMo's Avatar
RollaMo
A clicking sound as you describe can be caused by a loose terminal on either the negative or positive battery cable (either end).
Old Mar 19, 2011 | 09:52 PM
dh2683's Avatar
dh2683
If its a 2009 & you have a WORKING tender plugged in I don't think the battery is bad. Most get 5-7 years out of a battery when a tender is used.If you have a volt meter check the battery's charge level. Should be 12.6-12.8 VDC if fully charged.
Old Mar 19, 2011 | 11:43 PM
oct1949's Avatar
oct1949
was the tender pluged in ... if so then ckeck the batter nuts..
2yrs old, she should be good to go for 2-3 yrs more easy.
Old Mar 19, 2011 | 11:54 PM
Other Sheep's Avatar
Other Sheep
You might also want to check the charging voltage of your battery tender. It might be bad.
Old Mar 20, 2011 | 08:52 AM
handyhoward's Avatar
handyhoward
Was the battery tender plugged in to a continuous working plug... my buddy would plug his in and turn it on religiously every time he came back from a ride. Couldn't figure out why the battery wouldn't hold a charge over the winter... well... when he turned off the garage light and went into the house the plug turned off as well.....
Old Mar 20, 2011 | 09:13 AM
MNPGRider's Avatar
MNPGRider
Well, there's my Sunday funnies right there! Reminds me of Chevy Chase trying to get his Christmas lights to work!
Old Mar 20, 2011 | 09:56 AM
motorrader's Avatar
motorrader
I had the same situation yesterday. I tried to jump start it with my other bike and that failed also. The bike is in the shop getting diagnosed.
