oil capacity
Old Jun 5, 2011 | 06:38 PM
dhhollywood's Avatar
dhhollywood
Stage I
i Just had an oil change at a local shop for my 2010 softail classic and when i ran it on the highway for two days i noticed it made a weird sound like my air filter needed to be changed so i went to change the filter and noticed oil behind the filter, i also noticed oil ran down the oil tank under my dipstick, my question is did i damage anything on the bike like blow my seals and is my bike going to need costly repair? i think the kid that did the oil change put in too much oil, can this be fixed? and is my bike going to be ok?
Old Jun 5, 2011 | 07:33 PM
Lost1's Avatar
Lost1
Originally Posted by skully1200
I apologize for my ignorance, but this is my first big twin. I read the service manual and changed my fluids. I put in 3.5 quarts of oil as per the manual. (TC88). When I check it as per the manual, it's about midway between add and full. Is this right/normal? Should I be running 4 quarts?
I used to add 3.5 qts, run it till warm, then top off to Full, but like many others I started seeing more oil in my breather. Now I just put in 3.5 qts and call it good. That puts it anywhere from 1/2-3/4 to the full line and blowby isn't an issue.
I would recommend you go with 3.5 qts.
Old Jun 5, 2011 | 07:35 PM
Lost1's Avatar
Lost1
Your bike and its seals are fine- just too much oil was added. Use a hose or turkey baster to remove about a half qt of oil from the tank. If you can't do it this way, pull the drain plug for a second or two & drain out a half qt. Clean out the excess oil from the breather & you'll be good to go.
johnb3207
Apr 26, 2013 07:16 AM
Doc o
Oct 19, 2010 03:12 PM
RealEstateBiker
May 17, 2009 12:32 PM
acadien
Jul 25, 2007 12:50 PM
Jezcruzen
Oil Archive (no new posts)
Aug 8, 2005 12:33 PM
