cleaning engine fins
Old Aug 31, 2011 | 04:59 AM
lbienforcer's Avatar
lbienforcer
Stage I
Default How did you do this?
Did you use the Scotch Brite 3m to clean this? I wanna do mine as well. Bought a 2008 FLSTF from a guy who wasnt nearly as much of a clean freak as I am. He put 4k on the bike and never cleaned the fins. I tried using white diamond and mothers but after getting that on the black part and realizing how hard it was to get off I said screw that....lol
Old Aug 31, 2011 | 05:32 AM
SteveO-ll's Avatar
SteveO-ll
Well, one thing mentioned was cleaning them with simple green which is good, I also use scrubbing bubbles then rise off and dry. If you want then to really shine try some White Diamond polish on a rag then use a buffing wheel (a Dremel works good), they be really shine'n then.
Old Aug 31, 2011 | 05:42 AM
dickey's Avatar
dickey
Originally Posted by jdsmitty10
Maybe I should just get them diamond cut then hah... Wifey would go for that after a 3k rim job..
Either way, dull silver will be better than what I have. Previous owner let it get this way, now I need to fix it the best I can
Is it your bike & $$ or the wifey's?
Old Aug 31, 2011 | 10:01 AM
TennesseeMustangPerf's Avatar
Originally Posted by Stash905
Try a 3M Scotch Brite pad.
Another vote here. We use Scotchbrites in the body shop industry to rough up the clear coat. It does this without "shaping" the body. Use a brown SB, if that does not work then step up to a red. As an added bonus, the pad is thick enough to fit inside the fins just nicely.
Old Aug 31, 2011 | 10:11 AM
Ribaldmanikin's Avatar
Ribaldmanikin
Cut a q-tip in half, insert in dremel (low speed), and use lots of polish.
Personally, never tried it on the motorcycle, but it's pretty effective with small shiny things.
Old Aug 31, 2011 | 10:29 AM
Maclugie's Avatar
Maclugie
S100 spray bike wash.
Old Aug 31, 2011 | 12:24 PM
DinoVelvet's Avatar
DinoVelvet
I have asked in the past how to clean my engine fins, I tried the recommendations of s100 and other cleaning products.
Some of the fins have some discoloration/oxidation...
I am thinking they need sanded with a high grit.
What grit do you think I should go with? Autozone has an assortment up to 2500 grit. Should i just get that and try the highest and see if it works, if not, go down from there?
thanks,
Jon
a local shop here suggested I use some wheel acid that you get for cleaning rims. very careful not to get it on polished parts or they will turn white but you can get it on chrome.
spray the fins and the other painted engine parts that are dirty, let sit for a minute or two and then hose it off, maybe do it just before you wash your bike.
my fins and primary came out really nicely. have to do that maybe once every 2 or so years.
Old Aug 31, 2011 | 12:42 PM
Hooker 6's Avatar
Hooker 6
I use a sheetrock sponge sanding block to get the outside of the cooling fins, where it is suppose to be bare metal. It doesn't get them shiny, but sure gets rid of the corrosion. Then I use pig spit to bring out the black.on the interior sides of the fins.
RoadKing16
Jul 3, 2018 11:56 AM
rquest
Sep 27, 2017 12:09 PM
PierreG
Engine Mechanical Topics
Jul 23, 2015 11:58 AM
firstimer
Detailing
Jan 30, 2009 06:22 PM
mudrat_fat05
General Topics/Tech Tips
May 7, 2008 12:07 AM
