Have a knocking noise...
Old Apr 7, 2011 | 04:49 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by oct1949
Usually on a harley is means Ur motor is running, or U pipes are too quiet...
Did it just start making the noise, or did you just get the bike? When I first got a Harley after riding "metric" bikes, I thought it made so much mechanical noise it would not run a week...15 years later it is still running fine
Old Apr 7, 2011 | 09:25 PM
PattyD's Avatar
PattyD
Stage III
Thanks for all the responses. It is a 97 sportster. It has 7000 original miles on it. I don't know much about it, as this is my first Harley. I changed the oil, and primary fluid, changed the plugs, cleaned the air filter, and adjusted the primary chain. I really can't hear the ticking noise until it warms up. It seems to be coming from top of the motor in the rocker boxes. Is there a way to check to make sure it is getting the proper amount of oil to the rocker arms. The oil light does not come on.
Old Apr 7, 2011 | 10:22 PM
BassCatcher's Avatar
BassCatcher
Do a search, there are a hundred threads on the sportster clicking issue. It's normal. Mine sounded like a sewing machine sometimes.
Old Apr 8, 2011 | 06:46 AM
oldairboater's Avatar
oldairboater
Oil light should come on when you turn the key on and switch the handlebar switch to run. This tells you that the bulb is good. Once you start the bike the light goes out----oil pressure should be good to go. I would be willing to bet that what you are hearing is normal noise. No miles on the bike and if you used a good oil---it should be okay.
martin10
Sep 21, 2018 08:51 AM
JONNIEROCK
Dec 30, 2013 06:35 PM
TedMan
Exhaust System Topics
40
Apr 16, 2010 01:12 PM
jjb
Jun 13, 2009 06:59 AM
Hoosier XLC
Shovelhead
Jan 14, 2007 05:55 PM
