Throttle Grip Problem
Old May 11, 2011 | 06:54 AM
tacoma5432's Avatar
tacoma5432
Default Throttle Grip Problem
The grip on my throttle side came loose. The throttle still works but its a pain in the a$$ because the grip wants to keep turning when i get into it. I did not install the grips nor have I ever done any. What could be the problem here and or what holds the grips on? Someone said I probably just need to re-glue it. If thats the case what type of glue do you all recommend?
Old May 11, 2011 | 08:17 AM
rh8234's Avatar
rh8234
Throttle grip is not glued on. There's a couple screws in the clamp that tighten it to the bars. Tighten those screws and you should be fine.
Old May 11, 2011 | 09:37 AM
tacoma5432's Avatar
tacoma5432
Thanks. Will give that a try tonight
Old May 12, 2011 | 09:41 AM
oct1949's Avatar
oct1949
Not sure Ur whole throttle unit is loose or just Ur grip only..
Above fix is for the whole thing, if its just the grip then..
http://www.ehow.com/video_5538516_re...bar-grips.html
Old May 13, 2011 | 12:00 AM
wideglidebob's Avatar
wideglidebob
mine is glued had the same problem i had to squez the throttle hard to make it move, regluded and all is fine
Old May 14, 2011 | 12:57 PM
oct1949's Avatar
oct1949
Did U get her fixed,, What U'd end up doing.??
Old May 25, 2011 | 01:54 PM
Blackline Rolling's Avatar
Blackline Rolling
What type of glue is good to use for the left grip? I asked HD but the tech said they use "just regular glue" and didn't really want to give away his top secret in hopes that they can do it "for a small fee". Whatever, just need to know what kind of glue is recommended
Old May 25, 2011 | 07:40 PM
p51bombay's Avatar
p51bombay
cheap hair spray
518Train
Mar 12, 2013 08:48 PM
Drew91666
Dec 24, 2012 03:57 AM
Keithhu
Mar 6, 2012 05:32 PM
Nashville
Aug 6, 2009 06:04 PM
loseranacummins
Apr 19, 2009 09:59 PM
