Is blue loctite a given?
Old Jul 11, 2011 | 06:57 PM
Flinter's Avatar
Flinter
Default Is blue loctite a given?
For installing all of those little parts like coil covers, voltage regulators, etc.
And what does Harley use for a threadlocker? That white goop they put on bolts is awesome!
Old Jul 11, 2011 | 07:03 PM
SurfGuitar141's Avatar
SurfGuitar141
I use it for pretty much everything that requires thread locker.....
Old Jul 11, 2011 | 07:10 PM
piasspj's Avatar
piasspj
Unless it is threaded in to plastic.
Old Jul 11, 2011 | 07:12 PM
luc.who's Avatar
luc.who
there are some places you need red locktite, but mostly use the blue. Not sure what the factory loctite is. Dont use red unless called for in the manual and as piasspj said, dont use any when going into plastic...
Pmariner's Avatar
Pmariner
I beleive that white goop you are referring to is teflon sealant, not a locking sealant.
Old Jul 11, 2011 | 09:39 PM
Uncle G.'s Avatar
Uncle G.
The white goop is Loctite "Pipe Sealant With Teflon", I believe. At least that's what my service manual calls out for pipe plugs and the fuel petcock. It's a thread sealant, not a thread locker.
Old Jul 11, 2011 | 09:47 PM
Bluehighways's Avatar
Bluehighways
Yup!
Old Jul 11, 2011 | 09:52 PM
PistonPuller's Avatar
PistonPuller
Blue loctite when it drys up and you break the screw lose will look more white than blue.
Flinter's Avatar
Flinter
It may not be a threadlocker, but it does a fine job of it.
Thanks for the input guys. I just wasn't sure if all of those bolts were supposed to be loctited or not. I assumed that they were even if the instruction sheets don't specifically call for it.
My Dyna seems like it would shake most anything loose that didn't have it on there.
But it's one of the things I love about the bike...
Old Jul 11, 2011 | 10:16 PM
oldairboater's Avatar
oldairboater
Blue loctite if you want to keep it but might have to take it off sometime in the future. Red loctite is you plan on being dead or someone else will own the bike when it needs removing, plus you can't do without it. Thread sealant if you need to keep a liquid in without over-tightening.
